turn7 Posted October 8, 2006 Report Share Posted October 8, 2006 2000 S70 2.4 Non-TurboI have been experiencing a sporadic missfire/stumble at idle and at lower rpm's as the car begins to take off from a stop. This has been an ongoing thing for the last few months and for most of the time using super unleaded fuel resolved (masked) the issue. However, it never threw a code to know which cylinder this mis was happening on until just this past week. I have code P301 which I was told was a misfire on cylinder 1. I want to move the coil from that cylinder to another cylinder to see if the misfire follows the coil or stays on cylinder 1. Which cylinder is 1? I assume it is the cylinder closest to the timing belt but, want to ensure it isn't the one closest to the transaxle.Thanks for any help. Link to comment Share on other sites More sharing options...
the underlørd Posted October 8, 2006 Report Share Posted October 8, 2006 Which cylinder is 1? I assume it is the cylinder closest to the timing belt but, Thanks for any help.and you would be correct sir. Link to comment Share on other sites More sharing options...
MrWinkey Posted October 13, 2006 Report Share Posted October 13, 2006 2000 S70 2.4 Non-TurboI have been experiencing a sporadic missfire/stumble at idle and at lower rpm's as the car begins to take off from a stop. This has been an ongoing thing for the last few months and for most of the time using super unleaded fuel resolved (masked) the issue. However, it never threw a code to know which cylinder this mis was happening on until just this past week. I have code P301 which I was told was a misfire on cylinder 1. I want to move the coil from that cylinder to another cylinder to see if the misfire follows the coil or stays on cylinder 1. Which cylinder is 1? I assume it is the cylinder closest to the timing belt but, want to ensure it isn't the one closest to the transaxle.Thanks for any help.And that is exactly what the pros do... the ole' switcharoo and see if the missfire moves. You probably have a weak coil pack or crappy plugs ;) Link to comment Share on other sites More sharing options...
Seamus Posted October 13, 2006 Report Share Posted October 13, 2006 The coils often fail but I have seen plug problems with cars that are driven hard. Often times the coils flat die, and the plugs will randomly misfire... Link to comment Share on other sites More sharing options...
