sox2112 Posted October 11, 2006 Report Share Posted October 11, 2006 i just got my v70r gauges today and want to swap them out. ive looked everywhere for a guide to switch out the gauges but cant find one...any advice? Link to comment Share on other sites More sharing options...
the underlørd Posted October 11, 2006 Report Share Posted October 11, 2006 take off the dash cover. (search for "dash") then unclip the gauge cluster, and unplug the wire harnesses, then you have to take off the big black plastic box, and then unclip the plastic gauge cover, then take out the two screws per individual gauges, and gently pull them out, and put the new R gauges in. here's some pics Link to comment Share on other sites More sharing options...
sox2112 Posted October 11, 2006 Author Report Share Posted October 11, 2006 is the driver side of the dash supposed to be the only side that really moves when you take out all the screws? i couldnt get the plastic off the front so i just swaped the board from my C70 into the V70r cluster...that will work correct? all thats left is getting the clips back on...i cant figure out how to get them back on ...then comes the fun part putting the dash back together Link to comment Share on other sites More sharing options...
maiku Posted October 11, 2006 Report Share Posted October 11, 2006 you are screwed98 gauge won't work in 02 C70 Link to comment Share on other sites More sharing options...
sox2112 Posted October 11, 2006 Author Report Share Posted October 11, 2006 you are screwed98 gauge won't work in 02 C70thats fine but my v70r cluster is from a 2000 Link to comment Share on other sites More sharing options...
the underlørd Posted October 11, 2006 Report Share Posted October 11, 2006 ?dude. it's so easy. why fuck up your mileage? your car will now read the mileage that was on the 2000 V70R cluster. Link to comment Share on other sites More sharing options...
sox2112 Posted October 11, 2006 Author Report Share Posted October 11, 2006 ?dude. it's so easy. why monkey up your mileage? your car will now read the mileage that was on the 2000 V70R cluster.i took the board from my c70 cluster and just put it on the v70r cluster(after i took off the v70r board) because i couldnt get the plastic cover off...how will i monkey it up if im taking my original board and just moving over....it will still plug in the same and have the same miles Link to comment Share on other sites More sharing options...
Dougie B Posted October 11, 2006 Report Share Posted October 11, 2006 please tell me where you get those and how much!!!!!! Link to comment Share on other sites More sharing options...
the underlørd Posted October 11, 2006 Report Share Posted October 11, 2006 i took the board from my c70 cluster and just put it on the v70r cluster(after i took off the v70r board) because i couldnt get the plastic cover off...how will i monkey it up if im taking my original board and just moving over....it will still plug in the same and have the same miles are you replaceing the gauge faces only, and not using the whole cluster you got?-->QUOTE(Dougie B @ Oct 11 2006, 01:06 PM) ← please tell me where you get those and how much!!!!!! ebay, wrecking yards.. they go for around 200 ish. Link to comment Share on other sites More sharing options...
sox2112 Posted October 11, 2006 Author Report Share Posted October 11, 2006 are you replaceing the gauge faces only, and not using the whole cluster you got?--><div class='quotetop'>QUOTE(Dougie B @ Oct 11 2006, 01:06 PM) ←</div><div class='quotemain'><!--quotec--> please tell me where you get those and how much!!!!!! ebay, wrecking yards.. they go for around 200 ish.im using the physical cluster/gauges and the casing it came in...i couldnt get the front plastic off of the cluster so i took the electric board w/ the trip computer and odometer off of my c70 cluster and put it on the v70r cluster so i can just put that in because it was the electric board from the c70 that i have... Link to comment Share on other sites More sharing options...
the underlørd Posted October 11, 2006 Report Share Posted October 11, 2006 im using the physical cluster/gauges and the casing it came in...i couldnt get the front plastic off of the cluster so i took the electric board w/ the trip computer and odometer off of my c70 cluster and put it on the v70r cluster so i can just put that in because it was the electric board from the c70 that i have... the plastic comes off by like 8 lil clips.. it's pretty easy. once you take that ABS module off the top with the two lil torx screws. Link to comment Share on other sites More sharing options...
sox2112 Posted October 11, 2006 Author Report Share Posted October 11, 2006 the plastic comes off by like 8 lil clips.. it's pretty easy. once you take that ABS module off the top with the two lil torx screws.i know it comes off w/ the clips...i just cant seem to get them...i took off the abs module and put it on the v70r cluster as well...it should work since i just put my c70 board and abs module onto the v70r cluster correct? Link to comment Share on other sites More sharing options...
the underlørd Posted October 11, 2006 Report Share Posted October 11, 2006 i know it comes off w/ the clips...i just cant seem to get them...i took off the abs module and put it on the v70r cluster as well...it should work since i just put my c70 board and abs module onto the v70r cluster correct? Yup.. Link to comment Share on other sites More sharing options...
sox2112 Posted October 11, 2006 Author Report Share Posted October 11, 2006 Yup..thanks...ill post pics tonight when i finish...i gotta take out the 3 bolts under the top of the dash so i can completly take the dash piece off Link to comment Share on other sites More sharing options...
the underlørd Posted October 11, 2006 Report Share Posted October 11, 2006 thanks...ill post pics tonight when i finish...i gotta take out the 3 bolts under the top of the dash so i can completly take the dash piece off be sure to disconnect your battery, before you unclip the airbag connector. Link to comment Share on other sites More sharing options...
