MrWinkey Posted October 14, 2006 Report Share Posted October 14, 2006 Did you get any codes out of A-2 or A-6? they are the important ones?......but your flashing arrow is probably due to the PNP Link to comment Share on other sites More sharing options...
pwebb Posted October 14, 2006 Author Report Share Posted October 14, 2006 I only got codes from A1 A3 A7 B1 and B2.Does anyone know where I can locate a TPS? Can I get away with just buying the fuel pump insert, or do I have to get a complete system?also, I'm going through FCP. if you guys know where I can source these parts for cheaper that would be awesome. Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted October 14, 2006 Report Share Posted October 14, 2006 Hi MateI had a 93 GLT, often got codes for tps and cps, but if you are getting codes on the pnp it is likely your no start is connected to the pnp.Try shifting the gear selector back and forth 30 times then try to start it in Neutral. I occassionally needed to do this when the cold weather came, basically the PNP was stopping the car from starting.Hope this helpsMatt Link to comment Share on other sites More sharing options...
