TheMan5952 Posted October 14, 2006 Report Share Posted October 14, 2006 Slater, You know if the maf size is the same for S60's? Link to comment Share on other sites More sharing options...
JOHN96850R Posted October 14, 2006 Report Share Posted October 14, 2006 I put a vacuum gauge on the tube from the turbo to the airbox lid and got 5 inch lbs of vacuum.Then I taped into the airbox and there's 0 vacuum.The bigest restriction is the maf sensor not the airfilter..any suggestion on how to install a larger maf sensor?That test was done at 17psi. Link to comment Share on other sites More sharing options...
TheMan5952 Posted October 14, 2006 Report Share Posted October 14, 2006 Custom Housing? or find one that our sensor can drop into. Link to comment Share on other sites More sharing options...
Texas850Turbo Posted October 15, 2006 Report Share Posted October 15, 2006 I put a vacuum gauge on the tube from the turbo to the airbox lid and got 5 inch lbs of vacuum.Then I taped into the airbox and there's 0 vacuum.The bigest restriction is the maf sensor not the airfilter..any suggestion on how to install a larger maf sensor?That test was done at 17psi.Yeah, the thing is though that there are a lot more things that are more restrictive than the maf sensor...... <_< Link to comment Share on other sites More sharing options...
Fishey Posted October 15, 2006 Report Share Posted October 15, 2006 This is the only true CAI that I have seen on a 850T..http://mishilo.image.pbase.com/g3/45/59354..._0039Custom.jpghttp://k53.pbase.com/g3/45/593545/2/573605..._0038Custom.jpgAlso, no change in the battery. Link to comment Share on other sites More sharing options...
