prasamin Posted October 18, 2006 Report Share Posted October 18, 2006 so there is like an adapter or something?hub centric rings. email Scott at IPD Link to comment Share on other sites More sharing options...
boostwagboy Posted October 18, 2006 Author Report Share Posted October 18, 2006 hub centric rings. email Scott at IPD alright thanks! Link to comment Share on other sites More sharing options...
George @ ViVA Posted October 18, 2006 Report Share Posted October 18, 2006 Guys,Let's not speculate anymore...Fitment issues will be similar to the Pegasus. Mirzams are 5x108mm bolt pattern, 18" x8" with +46mm offset. PCD (Centerbore) is 63.1mm. You can NOT use hubcentric rings. If you do want to fit them on your 850, you will need to increase the centerbore diamter to 65.1mm.We'll be adding them to our online catalog in about a week's time.With regards to hubcentric rings, your best source is Discount Tire Direct. You will get high quality aluminum rings (in pretty much any size) at the lowest price anywhere. Link to comment Share on other sites More sharing options...
boostwagboy Posted October 18, 2006 Author Report Share Posted October 18, 2006 Guys,Let's not speculate anymore...Fitment issues will be similar to the Pegasus. Mirzams are 5x108mm bolt pattern, 18" x8" with +46mm offset. PCD (Centerbore) is 63.1mm. You can NOT use hubcentric rings. If you do want to fit them on your 850, you will need to increase the centerbore diamter to 65.1mm.We'll be adding them to our online catalog in about a week's time.With regards to hubcentric rings, your best source is Discount Tire Direct. You will get high quality aluminum rings (in pretty much any size) at the lowest price anywhere.alrighty! Link to comment Share on other sites More sharing options...
Datsun Z Posted October 18, 2006 Report Share Posted October 18, 2006 I've been looking at those myself, Let me know if/when you get them mounted. Link to comment Share on other sites More sharing options...
ViperVette Posted October 18, 2006 Report Share Posted October 18, 2006 George ft W! Link to comment Share on other sites More sharing options...
Texas850Turbo Posted October 18, 2006 Report Share Posted October 18, 2006 Those are probably the sexiest wheels I've seen in person on a Volvo....that picture doesn't do them justice at all! Good luck with fitting them wagboy... :tup: Link to comment Share on other sites More sharing options...
prasamin Posted October 19, 2006 Report Share Posted October 19, 2006 Guys,Let's not speculate anymore...Fitment issues will be similar to the Pegasus. Mirzams are 5x108mm bolt pattern, 18" x8" with +46mm offset. PCD (Centerbore) is 63.1mm. You can NOT use hubcentric rings. If you do want to fit them on your 850, you will need to increase the centerbore diamter to 65.1mm.We'll be adding them to our online catalog in about a week's time.With regards to hubcentric rings, your best source is Discount Tire Direct. You will get high quality aluminum rings (in pretty much any size) at the lowest price anywhere.Thanks for the info man. Link to comment Share on other sites More sharing options...
