MrLorence Posted October 18, 2006 Report Share Posted October 18, 2006 Im not to sharp in the area of batteries and such, but i can tell you that im pretty sure that i need to upgrade.The reason, im going to be placing system in the volvo and i dont want to have lights dimPlus, these are top notch batteriesSo..Can i run one of them in the car as a replacement to the one thats in there now? Link to comment Share on other sites More sharing options...
Owned Posted October 18, 2006 Report Share Posted October 18, 2006 Yes, you can run an Optima.No, it is not the solution to voltage drop. Link to comment Share on other sites More sharing options...
CAPT_BLOTTO Posted October 19, 2006 Report Share Posted October 19, 2006 upgrading to optima is a good choice.but you're doing it for the wrong reasons. Do you know your lights are going to dim?If they do look into integrating a cap or adding a high output alternator. Link to comment Share on other sites More sharing options...
Über855R Posted October 19, 2006 Report Share Posted October 19, 2006 I put in an optima simply because my battery kept dying. Since then I can run my battery for hours with minimal voltage drop. Yes I have a voltmeter. I run xbox dvd tv and music and haven't had a voltage issue or starting issue since the optima. It wasn't super easy to install, we had to remove the battery tray and reroute a couple wires to get the positive lead to reach but now it fits and is great. Wasn't really that hard either but wasn't direct bolt in for me. I think some of my auxillery wires were holding the leads so others might not have had that problem And if nothing else it looks cooler than a stocker. Plus I was able to lock it down with the stock tie down. Good to go. Link to comment Share on other sites More sharing options...
NGB Posted October 19, 2006 Report Share Posted October 19, 2006 I put in an optima simply because my battery kept dying. Since then I can run my battery for hours with minimal voltage drop. Yes I have a voltmeter. I run xbox dvd tv and music and haven't had a voltage issue or starting issue since the optima. It wasn't super easy to install, we had to remove the battery tray and reroute a couple wires to get the positive lead to reach but now it fits and is great. Wasn't really that hard either but wasn't direct bolt in for me. I think some of my auxillery wires were holding the leads so others might not have had that problem And if nothing else it looks cooler than a stocker. Plus I was able to lock it down with the stock tie down. Good to go.What size did you put in? Link to comment Share on other sites More sharing options...
b3atboxjr Posted October 24, 2006 Report Share Posted October 24, 2006 we have the same car... get the redtop 75/35. it's fits perfectly in the battery tray, though you'll need to pull on the cables a bit to get them onto the terminals. Link to comment Share on other sites More sharing options...
speedn_j Posted November 1, 2006 Report Share Posted November 1, 2006 i used a 34R optima ..bolted right in but i had to use a different negative cable clamp Link to comment Share on other sites More sharing options...
PharmD Posted November 1, 2006 Report Share Posted November 1, 2006 Have you perhaps considered a capacitor? That would likely help with some of your lights dimming when the subs hit. Link to comment Share on other sites More sharing options...
Owned Posted November 2, 2006 Report Share Posted November 2, 2006 Have you perhaps considered a capacitor? That would likely help with some of your lights dimming when the subs hit.Not always. It would depend on why he's getting voltage drop. Link to comment Share on other sites More sharing options...
speedn_j Posted November 2, 2006 Report Share Posted November 2, 2006 what about a yellow top deep cycle optima..? Link to comment Share on other sites More sharing options...
Owned Posted November 2, 2006 Report Share Posted November 2, 2006 what about a yellow top deep cycle optima..?What about it? Link to comment Share on other sites More sharing options...
speedn_j Posted November 2, 2006 Report Share Posted November 2, 2006 well alot of people that have high power stereos use the yellow top instead of a cap. . the deep cycle part of the battery acts as a capacator and keeps the voltage stable while the battery itself is still designed to be used as a starter battery. Link to comment Share on other sites More sharing options...
Owned Posted November 2, 2006 Report Share Posted November 2, 2006 well alot of people that have high power stereos use the yellow top instead of a cap. . the deep cycle part of the battery acts as a capacator and keeps the voltage stable while the battery itself is still designed to be used as a starter battery.No. A battery is a battery and a capacitor is a capacitor. People use deep cycle batteries because they lend themselves well to high cycle applications. Not because they "act like a cap." Also, your battery doesn't really do anything for your system untill the voltage drops to 12.8 and below. Anything higher than that, which it should be, is basically powered by the alt. The alt is also what is regulating the voltage, not the battery.Because the plates of a cap can store and release electrons very quickly, this makes them "smooth" power. A battery is much slower and does not have the same effect. Link to comment Share on other sites More sharing options...
speedn_j Posted November 2, 2006 Report Share Posted November 2, 2006 its all about results..http://www.optimabatteries.com/publish/opt...ml#000100010001look at number 14..http://www.optimabatteries.com/publish/opt...ml#000100010012 Link to comment Share on other sites More sharing options...
Owned Posted November 2, 2006 Report Share Posted November 2, 2006 its all about results..http://www.optimabatteries.com/publish/opt...ml#000100010001look at number 14..http://www.optimabatteries.com/publish/opt...ml#000100010012I stopped reading the first link when I saw '93 Honda Civic. Number 14 is reiterating my point about high cycle applications. Good job, though. Link to comment Share on other sites More sharing options...
