gdizzle Posted November 7, 2006 Report Share Posted November 7, 2006 k, i run 20 psi, and have a 3" DP, no cat, and my car doens't ignite on a backfire. a test pipe and a 3" DP aren't the same thing...Mine does! It's due to a rich condition though. :) Link to comment Share on other sites More sharing options...
Ipd Posted November 7, 2006 Report Share Posted November 7, 2006 $0.02Factory REAR O2 sensors will normally run in the 0.5v - 0.7v range Slightly lean due to the cat convertors usage of the left over oxygen to catalyse polutants.I have yet to see a rear O2 sensor that was not narrow band.O2 spacers work great for Volvo's without cats, however spacing is critical.GpMoto sells a nice unit that I have used a number of times with good success.Any thoughts.....-Lucky Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted November 7, 2006 Report Share Posted November 7, 2006 $0.02Factory REAR O2 sensors will normally run in the 0.5v - 0.7v range Slightly lean due to the cat convertors usage of the left over oxygen to catalyse polutants.I have yet to see a rear O2 sensor that was not narrow band.O2 spacers work great for Volvo's without cats, however spacing is critical.GpMoto sells a nice unit that I have used a number of times with good success.Any thoughts.....-LuckyWas this used successfully on a motronic 4.3/4.4 car? Do you work with IPD?Are you talking about the GPMoto O2 Boss? Part # 11151 CEL Boss: PN 11151 Fix annoying check engine lights with this mechanical fix. This boss removes the o2 from the flow of exhaust so that the sensor runs cooler with an aftermarket exhaust. Aluminum construction for lightwieght. Near universal fit for most modern cars. ? Link to comment Share on other sites More sharing options...
gdizzle Posted November 7, 2006 Report Share Posted November 7, 2006 Was this used successfully on a motronic 4.3/4.4 car? Do you work with IPD?Are you talking about the GPMoto O2 Boss? Part # 11151 CEL Boss: PN 11151 Fix annoying check engine lights with this mechanical fix. This boss removes the o2 from the flow of exhaust so that the sensor runs cooler with an aftermarket exhaust. Aluminum construction for lightwieght. Near universal fit for most modern cars. ?That is Lucky from IPD, so yes, he works there. Good guy. Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted November 7, 2006 Report Share Posted November 7, 2006 Thanks Greg for confirming. Curious to see if it has worked on Motronic 4.3/4.4 cars. :) Link to comment Share on other sites More sharing options...
Ipd Posted November 7, 2006 Report Share Posted November 7, 2006 Was this used successfully on a motronic 4.3/4.4 car? Do you work with IPD?Are you talking about the GPMoto O2 Boss? Part # 11151 CEL Boss: PN 11151 Fix annoying check engine lights with this mechanical fix. This boss removes the o2 from the flow of exhaust so that the sensor runs cooler with an aftermarket exhaust. Aluminum construction for lightwieght. Near universal fit for most modern cars. ?Yes Both motronic 4.4 and 4.3Yes, I work for Ipd.Yes, I am talking about that part.It's not the end all answer to cat delete, but it has worked for me.The other way to go for the super cheap is remove the rear O2 entirely and setup a voltage divider with a potentiometer so thatthe voltage that normally heats the O2 is tapped and feedback at 0.6-0.7 volts on the signal line.Its' the 60 cent fix!! Although this method is also not perfect.The best thing (perfect world) is to buy a high flow cat as mentioned previously, or remove the code in the ECU that polls the rear O2 voltage line.-Lucky Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted November 7, 2006 Report Share Posted November 7, 2006 Thanks. Regarding the voltage divider, I am very inept when it comes to that, is this something that you currently have for sale? Link to comment Share on other sites More sharing options...
Ipd Posted November 7, 2006 Report Share Posted November 7, 2006 Thanks. Regarding the voltage divider, I am very inept when it comes to that, is this something that you currently have for sale?The voltage divider is nothing we currently sell since it is illegal to modify an emissions device, of course I was simply using that for educational purposes myself -Lucky Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted November 7, 2006 Report Share Posted November 7, 2006 The voltage divider is nothing we currently sell since it is illegal to modify an emissions device, of course I was simply using that for educational purposes myself -Lucky I appreciate the example. Link to comment Share on other sites More sharing options...
