Geevs Posted October 26, 2006 Report Share Posted October 26, 2006 Looking at this 4-channel amps as it selling new for a hundred bux in ebay.Are these decent amps to drive some 5.25 components and a JL 12W0? I understand Che'Admin is running the higher-end Mean Machine series. Link to comment Share on other sites More sharing options...
CAPT_BLOTTO Posted October 26, 2006 Report Share Posted October 26, 2006 you want to run 2 5.25 speakers AND a jl sub off the same amp at the same time?say goodbye to your speakers. Link to comment Share on other sites More sharing options...
Geevs Posted October 26, 2006 Author Report Share Posted October 26, 2006 you want to run 2 5.25 speakers AND a jl sub off the same amp at the same time?say goodbye to your speakers.Yep. Why would it blow out the speakers? The lower rated amp is 2/3/4 channel. The 5.25 speakers are rated at 125wrms. 12w0 is rated at 125wrms as well. Link to comment Share on other sites More sharing options...
Ivanfbi Posted October 26, 2006 Report Share Posted October 26, 2006 what are those speakers that have 125w rms? you sure it's not peak power rating? I would get the higher model amp and turn the gains down. Link to comment Share on other sites More sharing options...
maiku Posted October 26, 2006 Report Share Posted October 26, 2006 you'll need more wattage if you're running your w0 and 4 speakers off that amp Link to comment Share on other sites More sharing options...
Owned Posted October 26, 2006 Report Share Posted October 26, 2006 The Super Sport SS 100.4 would be great if your comp set is a 2 ohm set. You'll under-power them a bit if they're 4 ohm. If the comp set is 2 ohm, and the W0 is 4 ohm, you can bridge the two rears for your sub and run each front chan to each x-over. Done deal, it will sound nice. If the comp set is 4 ohm and you have a 8 or 12 ohm W0, it won't be the greatest setup, but will work, technically. If both are 4 ohm it will be a decent setup. what are those speakers that have 125w rms? you sure it's not peak power rating? 125 RMS is not unheard of for a 2-way comp set. I've seen 150 RMS 5.25 sets before. I know one of CDT's 3-way comp sets is almost 200 RMS. you'll need more wattage if you're running your w0 and 4 speakers off that amp He said he's only running the comp set and sub... Link to comment Share on other sites More sharing options...
Geevs Posted October 26, 2006 Author Report Share Posted October 26, 2006 The Super Sport SS 100.4 would be great if your comp set is a 2 ohm set. You'll under-power them a bit if they're 4 ohm. If the comp set is 2 ohm, and the W0 is 4 ohm, you can bridge the two rears for your sub and run each front chan to each x-over. Done deal, it will sound nice. If the comp set is 4 ohm and you have a 8 or 12 ohm W0, it won't be the greatest setup, but will work, technically. If both are 4 ohm it will be a decent setup.The 5.25 comps are RCA Mobile RC5250C (rcamobile.com) 4 ohms. I was skeptical too about the 125w rms 250w max rating but at C$50 a pair brand new I got 2 pairs. Despite the "RCA" brand, they look well-made and sound decent altho they are currently running off the stock 50x4w R amp. The 12w0 is 4 ohms.As owned sorta suggested, I'm planning to run the 4 5.25 comps in parallel off the front channels and the single 12w0-4 off the bridged rear channels. Will this work? Link to comment Share on other sites More sharing options...
Owned Posted October 26, 2006 Report Share Posted October 26, 2006 The 5.25 comps are RCA Mobile RC5250C (rcamobile.com) 4 ohms. I was skeptical too about the 125wrms 250mrms rating but at C$50 a pair brand new I got 2 pairs. Despite the "RCA" brand, they look well-made and sound decent altho they are currently running off the stock 50x4w R amp. The 12w0 is 4 ohms.As owned sorta suggested, I'm planning to run the 4 5.25 comps in parallel off the front channels and the single 12w0-4 off the bridged rear channels. Will this work? Two 4 ohm comp sets would give the amp a 2 ohm load. This would work. Link to comment Share on other sites More sharing options...
Geevs Posted October 27, 2006 Author Report Share Posted October 27, 2006 Two 4 ohm comp sets would give the amp a 2 ohm load. This would work.Great, thanks!! Link to comment Share on other sites More sharing options...
maiku Posted October 27, 2006 Report Share Posted October 27, 2006 that's sorta how i'm running my setupfirst 2 channels are speakerslast 2 channels are bridged for sub Link to comment Share on other sites More sharing options...
Geevs Posted October 27, 2006 Author Report Share Posted October 27, 2006 that's sorta how i'm running my setupfirst 2 channels are speakerslast 2 channels are bridged for subDidn't know Planet Audio 4-ch amps can run in 3-ch mode. I emailed them but they didn't reply.Are you running the front channels in 2 or 4 ohm load? Link to comment Share on other sites More sharing options...
maiku Posted October 27, 2006 Report Share Posted October 27, 2006 both front channels are each 2ohm load (i believe)sub is 4ohm Link to comment Share on other sites More sharing options...
PharmD Posted November 1, 2006 Report Share Posted November 1, 2006 Probably not going to be able to do 2 5.25's and a sub off the SAME amp, 4 channel or whatever the case may be. Link to comment Share on other sites More sharing options...
