trgft Posted October 26, 2006 Report Share Posted October 26, 2006 Following my last post about test pipe. does anyone make me7 software that eliminates the need for a rear o2? Link to comment Share on other sites More sharing options...
maiku Posted October 26, 2006 Report Share Posted October 26, 2006 any good tuner can do it Link to comment Share on other sites More sharing options...
garbergtsi Posted October 27, 2006 Report Share Posted October 27, 2006 so its impossible? Link to comment Share on other sites More sharing options...
Texas850Turbo Posted October 27, 2006 Report Share Posted October 27, 2006 No, all you'd need is to have your ECU reflashed by a reputable company. Link to comment Share on other sites More sharing options...
garbergtsi Posted October 27, 2006 Report Share Posted October 27, 2006 like who? i have never seen that feature advertised Link to comment Share on other sites More sharing options...
prasamin Posted October 27, 2006 Report Share Posted October 27, 2006 No, all you'd need is to have your ECU reflashed by a reputable company.ME7, not motronic Link to comment Share on other sites More sharing options...
trgft Posted October 27, 2006 Author Report Share Posted October 27, 2006 so far, the answer is any tune shop can do it? Link to comment Share on other sites More sharing options...
BOOSTPHREAK Posted October 27, 2006 Report Share Posted October 27, 2006 so far, the answer is any tune shop can do it?NO! you need a good TUNER with the approriate software, connections, and info to tune it and delete the rear o2 sensor.PS it is easier to get high hp with out bypassing emissions. :) Link to comment Share on other sites More sharing options...
prasamin Posted October 27, 2006 Report Share Posted October 27, 2006 check swedespeed, they might be able to help you therethey'll help you with your hemorrhoid problems, but that's about it.Your car has newer software, there is limited info on it, and it is a bit more difficult to unlock. If you find a tuner that can flash your ECU, then you're lucky.The only names that come to mind are IPD/MTE and Evolve. OR, if there was a Euro/Canadian model for your car, you can get the Euro/Canadian ECU somehow, drop that in, and call it a day. Link to comment Share on other sites More sharing options...
azinwa Posted October 27, 2006 Report Share Posted October 27, 2006 The rear O2 sensor is used to monitor the Oxygen storage capacity of the Catalitic Converter.Most new cars with WB Air Fuel Ratio sensors upstream use both up and downstream to base longterm fuel trim as well.You do not need to remove the post cat O2 sensor in order to make power!Bert Link to comment Share on other sites More sharing options...
crazykn Posted October 29, 2006 Report Share Posted October 29, 2006 I know InMotion can do it. They gave me all sorts of programming capabilites for me if I send my ECU into them. They could delete things like EGR and such, so the rear O2 should be possible. Just google 'InMotion ECU' Link to comment Share on other sites More sharing options...
leurven Posted October 29, 2006 Report Share Posted October 29, 2006 Tony at EPLabs in Stratford, CT can probably reflash it to eliminate the need for a 2nd O2 sensor. Why do you want rid of it anyway? Link to comment Share on other sites More sharing options...
Nerdhotrod Posted November 3, 2006 Report Share Posted November 3, 2006 Tony at EPLabs in Stratford, CT can probably reflash it to eliminate the need for a 2nd O2 sensor. Why do you want rid of it anyway?This is very easy...We do this on many makes and models. Link to comment Share on other sites More sharing options...
