Noahkk19 Posted October 31, 2006 Report Share Posted October 31, 2006 seems to be only after a decent to long drive that when im in the midst of comming to a complete stop my oil light flickers on and off really fast. Sometimes it'll flicker just a little bit when i've put the car in neutral, never stays lit for even a second. It usually happens when the A/C is on but today it happened with no A/C. Whaaaat on earth is going on?95 850 T-5R Link to comment Share on other sites More sharing options...
the underlørd Posted November 1, 2006 Report Share Posted November 1, 2006 what's the oil level? Link to comment Share on other sites More sharing options...
drlava Posted November 1, 2006 Report Share Posted November 1, 2006 It's bad news, I can tell you that much. Likely the oil pick-up o-rings need to be replaced, which involves taking off the oil pan underneath. Also could be an oil clog or really worn oil seals. Is there a loud clicking noise when you first start, or a puff of blue smoke out the tailpipe? Link to comment Share on other sites More sharing options...
Noahkk19 Posted November 1, 2006 Author Report Share Posted November 1, 2006 the oil level is perfect...I recently had a valve job done and got new rings so that's not the problem. I did have the blue smoke and what not before this but got it all covered . And I don't get ticking even on cold days, engine runs perfectly Link to comment Share on other sites More sharing options...
Chopper Posted November 1, 2006 Report Share Posted November 1, 2006 I hope it's not a real oil pressure problem, but if it is be careful. The Volvo oil pressure light is on a switch. Below a certain pressure it comes on. The oil pressure sender is located on the front of the block below the intake manifold/head near the middle. Check to see if all the wiring looks good, may be a short rubbing in and out. Link to comment Share on other sites More sharing options...
Volvo Virgin Posted November 1, 2006 Report Share Posted November 1, 2006 Get a hand held oil pressure guage,take out the oil pressure sending unit and thread the oil pressure guage in to get an actual reading.That way you'll know for sure if you have pressure.If you do,change the sending unit while you have it out and see if that helps. Link to comment Share on other sites More sharing options...
Guest Guest Posted November 1, 2006 Report Share Posted November 1, 2006 Get a hand held oil pressure guage,take out the oil pressure sending unit and thread the oil pressure guage in to get an actual reading.That way you'll know for sure if you have pressure.If you do,change the sending unit while you have it out and see if that helps.Which way are you getting to the sending unit. Seems theres some obstacles on turbos if you go from the bottom. From the top seems like the manifold has to come off. Any tips to get to it? Link to comment Share on other sites More sharing options...
Chopper Posted November 1, 2006 Report Share Posted November 1, 2006 You can reach it from the bottom. No more obstacles on the front of the block in this area than you would have with an NA. It is hard to reach, but on my 850 I did remove the stock oil pressure switch and replace it with an autometer electronic sender (needed an adaptor), and I was able to do it from the bottom. Certainly frustrating. If you want to make it easy go ahead and take out the intake manifold, it's actually not very hard. Link to comment Share on other sites More sharing options...
