Modus Posted November 1, 2006 Report Share Posted November 1, 2006 Replaced gas cap, gas filler tube gasket, clamp and roll over valve. Still have the light. I checked the charcol canister and the vacuum lines. They seem ok.is thier something that i'm missing from under the hood? Any sugestions? Link to comment Share on other sites More sharing options...
Guest Burke Posted November 1, 2006 Report Share Posted November 1, 2006 I am chasing this same problem on my 1997 NA 850 wagon. The dealer said it was the evaporative valve (which they replaced) but I am still getting the same code, and I havn't had time to take it back to the dealer yet. Someone told me that there is a smoke test that the dealer can do to find the leak, but I don't know whether they actually did that on my car or not (I did not know about the smoke test until after I took it to them).Also there is a vacuum elbow underneath the power steering pump that can leak; I haven't tried to find that one yet.Good luck and let us know if you find the problem. Link to comment Share on other sites More sharing options...
Modus Posted November 2, 2006 Author Report Share Posted November 2, 2006 It's funny to say at least, I just don't know where else to look. Generic OBDII reads PO442 which states "small emmissions leak detected"And the Volvo DTC reads EFI-612 which is "Fuel tank system, small Leak" signal Lowany one else know? Link to comment Share on other sites More sharing options...
Guest Guest Posted November 2, 2006 Report Share Posted November 2, 2006 It's funny to say at least, I just don't know where else to look. Generic OBDII reads PO442 which states "small emmissions leak detected"And the Volvo DTC reads EFI-612 which is "Fuel tank system, small Leak" signal Lowany one else know?In the trunk where the fuel pump is take off the cover and see if you smell anything there. My car has a slight odor there but I have no codes. Some people have gotten leaks out of hoses in that area. Link to comment Share on other sites More sharing options...
Guest burke Posted November 2, 2006 Report Share Posted November 2, 2006 There is a thread over on swedespeed that I started some time ago that has a few more clues:http://forums.swedespeed.com/zerothread?id=59895But I still haven't solved my problem. I can turn off the code, but then in a few weeks it comes back. Link to comment Share on other sites More sharing options...
