Chopper Posted November 2, 2006 Report Share Posted November 2, 2006 Hello all,I have my head off, and in the process of replacing all the coolant hoses. Where the hard coolant pipe (that runs behind the head an parallel to it) meets the water pump housing, it is slightly flexible. Is there an O-ring or gasket where this connection is located? If so, how is it removed/reinstalled?Thanks! Link to comment Share on other sites More sharing options...
RussB Posted November 2, 2006 Report Share Posted November 2, 2006 There is a gasket...One was included in th Elring head set I got from FCP Link to comment Share on other sites More sharing options...
Chopper Posted November 2, 2006 Author Report Share Posted November 2, 2006 Does the coolant pipe just slide right out, or do you need to remove the water pump? Link to comment Share on other sites More sharing options...
crazykn Posted November 2, 2006 Report Share Posted November 2, 2006 The pipe should slide out, its not be hindered by the water pump. The gasket, which I forgot where to obtain (besides the dealer), looks very similiar to the turbo return line and EGR gasket. Link to comment Share on other sites More sharing options...
Chopper Posted November 2, 2006 Author Report Share Posted November 2, 2006 Thanks! I'll take pictures to follow up. Link to comment Share on other sites More sharing options...
