elfnmagik Posted November 2, 2006 Report Share Posted November 2, 2006 New front rotors are warped after about 15K. Got worse and worse along the way and I can't stand it no-mo.I noticed FCP has a note that they're carrying Zims and Brems only made in Europe now. Not looking for performance so I guess it would be a coin toss between the two or do the Zimms still seem have the edge amongst members?For the money though, what is the concensus on these? I don't really need the rears (knock on wood). Link to comment Share on other sites More sharing options...
matt b Posted November 2, 2006 Report Share Posted November 2, 2006 New front rotors are warped after about 15K. Got worse and worse along the way and I can't stand it no-mo.I noticed FCP has a note that they're carrying Zims and Brems only made in Europe now. Not looking for performance so I guess it would be a coin toss between the two or do the Zimms still seem have the edge amongst members?For the money though, what is the concensus on these? I don't really need the rears (knock on wood).How many miles do you have on it ? It seems weird that you would warp new rotors that quickly, is your front suspension stock, it could have an effect on it. I usually let off the brakes (when I can) if I see that I'm going to hit a bump, I tore up rotors on a GTI that way before. Link to comment Share on other sites More sharing options...
elfnmagik Posted November 2, 2006 Author Report Share Posted November 2, 2006 Everything's been replaced on the front end except the hub and rack. New rotors/pads/rebuilt calipers/lines were all done at the same time. Rotors and pads were broken in correctly. It started showing up about 2k later and has gotten worse over time. Link to comment Share on other sites More sharing options...
elfnmagik Posted November 3, 2006 Author Report Share Posted November 3, 2006 OK. I just ordered these, but fronts only.I'm thinking about going with either Hawk HPS or Akebono. Good match? Link to comment Share on other sites More sharing options...
maiku Posted November 3, 2006 Report Share Posted November 3, 2006 warp rotors could be a sign of bad wheel alignment, or overtorqued lug nuts Link to comment Share on other sites More sharing options...
elfnmagik Posted November 3, 2006 Author Report Share Posted November 3, 2006 Neither of which is my case. Link to comment Share on other sites More sharing options...
Mesoam Posted November 3, 2006 Report Share Posted November 3, 2006 bedding in your brakes propperly?what pads are you using? Link to comment Share on other sites More sharing options...
elfnmagik Posted November 4, 2006 Author Report Share Posted November 4, 2006 Yup. Everything by the bookCan't remember right off hand what the pads were but I got them from FCP. They don't carry them any longer.The last vehicle I had that suffered from similar problems was an '01 Outback wagon. The dealer threw rotors at it like there was no tomorrow. They never were able to find the source. It might be interesting to see a poll on how many people have had a simlar experience with new pads/rotors that went south within a short time. Anyway, I'm beyond that at this point and have already purchased the new rotors and want to know what others think about the pad combo's I've mentioned. Thanks. Link to comment Share on other sites More sharing options...
Mesoam Posted November 4, 2006 Report Share Posted November 4, 2006 Almost sounds like you have PBR metal master pads....They are a known to warp rotors due to the excess heat build up (yes even with your drilled rotors) Link to comment Share on other sites More sharing options...
Masque Posted November 4, 2006 Report Share Posted November 4, 2006 The last vehicle I had that suffered from similar problems was an '01 Outback wagon. The dealer threw rotors at it like there was no tomorrow. They never were able to find the source. It might be interesting to see a poll on how many people have had a simlar experience with new pads/rotors that went south within a short time.Could be a warped wheel hub. Torquing your rotors down onto a warped surface will cause them to conform to that surface. It's like a warping factory at that point. Are both your rotors warping? Link to comment Share on other sites More sharing options...
beachnut Posted November 4, 2006 Report Share Posted November 4, 2006 I had that same problem with eBay Brembo rotors and Ebc greenstuff pads. I did everything by the book as well, done many brake jobs before, but they warped in no time. I'm like 99% sure it was the pads. Now I'm on Zimmermans with PBR Ultimates ... I have a very, very slight warp but it's only noticeable at high speeds. Next time I'm swearing off drilled/slotted rotors and getting solids. Link to comment Share on other sites More sharing options...
MadeInJapan Posted November 4, 2006 Report Share Posted November 4, 2006 I'm glad I always stick with OEM pads (though dusty). I've never had warpped rotors....have used solid Brembo, Zimmerman's and some cross-drilled & slotted Brembo's. Link to comment Share on other sites More sharing options...
beachnut Posted November 4, 2006 Report Share Posted November 4, 2006 True, I'm going back to oem pads too. The PBR's are noisy and dust just as mcuh. Link to comment Share on other sites More sharing options...
prasamin Posted November 4, 2006 Report Share Posted November 4, 2006 Mexican Brembos work just fine on my car. Link to comment Share on other sites More sharing options...
Boomin850 Posted November 4, 2006 Report Share Posted November 4, 2006 I burned up and warped my ebay specials just bedding the pads...Go all oem Link to comment Share on other sites More sharing options...
