stew Posted November 9, 2006 Report Share Posted November 9, 2006 Hi all,Just replaced the round upper torque bushing on top of the motor approx 2 months ago. Was able to make own press so decided to go with OEM bushing. Was checking the oil etc the other day and noticed that the bushing had moved and was sticking out the side of the mount that you press it in from. ie it is no longer evenly spaced inside the mount.Has anyone that has pressed the bushing in had this happen? If so is it a case of just repressing the bushing back into the mount?As we all know it is very hard to get the new mount in and hence I thought it would never move!!!!!CheersStew ;) Link to comment Share on other sites More sharing options...
prasamin Posted November 9, 2006 Report Share Posted November 9, 2006 if it moved, you should check the firewall bushing under the wiper cowl Link to comment Share on other sites More sharing options...
Guest Guest_whilst_* Posted November 9, 2006 Report Share Posted November 9, 2006 Hi all,Just replaced the round upper torque bushing on top of the motor approx 2 months ago. Was able to make own press so decided to go with OEM bushing. Was checking the oil etc the other day and noticed that the bushing had moved and was sticking out the side of the mount that you press it in from. ie it is no longer evenly spaced inside the mount.Has anyone that has pressed the bushing in had this happen? If so is it a case of just repressing the bushing back into the mount?As we all know it is very hard to get the new mount in and hence I thought it would never move!!!!!CheersStew Hi. I did the same thing,and sure enough,mine moved too.I just used a brass punch/hammer and tapped it in.So far so good. Link to comment Share on other sites More sharing options...
stew Posted November 13, 2006 Author Report Share Posted November 13, 2006 Hi. I did the same thing,and sure enough,mine moved too.I just used a brass punch/hammer and tapped it in.So far so good.Pasamin - Checked the mount under the wiper cowl. It has definitely cracked so will replace this ASAP. I pressed the bushing back in so will keep an eye on it.ThanksStew Link to comment Share on other sites More sharing options...
BeachRat Posted November 13, 2006 Report Share Posted November 13, 2006 Pasamin - Checked the mount under the wiper cowl. It has definitely cracked so will replace this ASAP. I pressed the bushing back in so will keep an eye on it.ThanksStewI have a urethane bushing in both sides of the upper torque mount. Mine also moves, but I believe it's due to alignment issues created from a front-end accident and not the installation. Pull up next to another 850 to see if your motor is shifted over like mine... makes things exciting! Link to comment Share on other sites More sharing options...
