DanO Posted November 13, 2006 Report Share Posted November 13, 2006 It is part of our Scandinavian heritage that things be made to last. Perhaps the most visible expression of Volvo quality is the continued durability of Volvos that were built a decade ago. According to a recent independent study by Polk, the median life expectancy of all Volvos in service is 18.6 years. And Volvo is the only car company with a High Mileage Club. These impressive facts help demonstrate another Volvo theme: that quality is an underlying principle of everything we do.Consider our paint and rust-proofing processes: During construction, every critical joint receives a zinc welding primer. Body components are assembled to extremely precise standards and caulking compounds seal all body joints. A corrosion resistant zinc coating is applied to all areas of the car susceptible to rust. The body is etched with an acid spray to give the primer a firm grip. But we are not satisfied with simply immersing the body in primer. Going an extra step, we apply opposite electric charges to the body and primer. The result is an attraction that creates bonds of optimum thickness and exceptional uniformity. In all, seven layers of primers, sealers, and coatings are applied. Special polyester-based formulas are applied to the lower parts of the body to help protect against chipping. To further reduce corrosion, anti-corrosive gel is sprayed into body sections that can trap moisture. Engine and suspension systems are sprayed with a rust-proofing oil. Finally, the inner fenders, which receive a relentless assault from road grit, sand, stones and salt, are protected by fender liners installed in all four wheel wells.mad.gifWHEEL WELLS ALSO USE TO GET COVER WITH COSMILEEN ENTIRELY , NOW IT'S A FENDER WELL LINEN !DON'T WE GET THSES LINES ON FORD ESCORTS ??I Pulled Out the Lines No Coating ON Inner Fender Wells : At all on the New Volvo's , I also Pull the Plugs from the So Called Suscepialbe Places , and they only Had Bottom 3/4 Inch Coated HELLO , these Area will Load Up , don't Let Volvo Bull S - You about the being Green Crap , as this is Just a way to Say Your VolvoWill Now get Recyled in 8 Yrs, instead of 14-16 Yrs. !I for One , will be talking to - Volvo Rep and Documneting This BS , as I'm a Quality Control Inspectorthat's QA Eng. III Tech Suppot 15 Yrs. !!I hate Big Company's Bully around with Our Money and Our Faith in a Proven Product !My 2001 was Completely Coated Everywhere , and Had the Lower Panels shot all the way Up to the Roof !Plus Engine Bay ! ( Not On the New Ones ) !Let Me See - Volvo -Winter 9 Months out of the Yr. , Heated Seats , and V50 Heading to Upstate NY !DO YOU THINK IT , MIGHT NEED FULL PROTECTION - DDDAAAA HELL YA !THEY ARE PLAYING US FOR IDIOTS - ( DON'T LET THEM ) mad.gif Link to comment Share on other sites More sharing options...
