96PlatinumEdition850 Posted November 16, 2006 Report Share Posted November 16, 2006 I have the amp power wire hooked up, remote wire, and ground wire all hooked up. I did a test(turned on the car) and the amp didn't power on. Do I need the RCA cables hooked up for the amp to get power? Thanks! Link to comment Share on other sites More sharing options...
steve s Posted November 16, 2006 Report Share Posted November 16, 2006 no. assume if u have the remote wire connected properly...the amp won't turn on until u turn on the head unit. Link to comment Share on other sites More sharing options...
b3atboxjr Posted November 16, 2006 Report Share Posted November 16, 2006 make sure you have the fuse in and its not broken. i'd also check if you simply have the wrong remote lead from yer stereo hooked up.it's blue/white if you have an aftermarket. Link to comment Share on other sites More sharing options...
Guest Guest Posted November 17, 2006 Report Share Posted November 17, 2006 make sure you have the fuse in and its not broken. i'd also check if you simply have the wrong remote lead from yer stereo hooked up.it's blue/white if you have an aftermarket.yes if you have it hooked up to the wrong wire on the aftermarket it would be the power antenna wire. The amp would work though, just only on the radio setting. Link to comment Share on other sites More sharing options...
tgill Posted November 17, 2006 Report Share Posted November 17, 2006 ^^ oops forgot to login that was me. Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted November 17, 2006 Author Report Share Posted November 17, 2006 My ground wasn't good enough, got it all fixed. Installed, hits great. Tomorrow I'm buying all the peel and seal I can for the trunk. Link to comment Share on other sites More sharing options...
Nucleareskimo Posted November 17, 2006 Report Share Posted November 17, 2006 you could try connecting the remote wire to another power source that you know will turn on or is always on to test and see if the remote wire is the problem. Link to comment Share on other sites More sharing options...
Datsun Z Posted December 6, 2006 Report Share Posted December 6, 2006 My ground wasn't good enough, got it all fixed. Installed, hits great. Tomorrow I'm buying all the peel and seal I can for the trunk.Don't pay too much for that stuff, i work at best buy and the retail for it is like 220 for a trunk kit and i get it for 60... Link to comment Share on other sites More sharing options...
