Phil94850 Posted November 22, 2006 Report Share Posted November 22, 2006 how do you get the switch out for the sunroof to replace the bulb ? Link to comment Share on other sites More sharing options...
AlvinL Posted November 22, 2006 Report Share Posted November 22, 2006 how do you get the switch out for the sunroof to replace the bulb ?You may have one of those that requires the board to be de-soldered to allow you to get the bulb out. Link to comment Share on other sites More sharing options...
maiku Posted November 22, 2006 Report Share Posted November 22, 2006 if it's the standard "rounded" switches, just take a flat head and literally wedge it outit should pop right out Link to comment Share on other sites More sharing options...
Zappo Posted November 22, 2006 Report Share Posted November 22, 2006 if it's the standard "rounded" switches, just take a flat head and literally wedge it outit should pop right outThat is correct. For the sunroof switch, it will be the round white thing on the back of the switch. Turn to remove and the light will come out.Only the info switch requires disassembly of the switch to change the light. Link to comment Share on other sites More sharing options...
ACES70 Posted November 22, 2006 Report Share Posted November 22, 2006 That is correct. For the sunroof switch, it will be the round white thing on the back of the switch. Turn to remove and the light will come out.Only the info switch requires disassembly of the switch to change the light.On a similar note, what about the lights in the stereo head unit, it seems like my top right and bottom left are the only parts that are lit up. Link to comment Share on other sites More sharing options...
matt b Posted November 22, 2006 Report Share Posted November 22, 2006 On a similar note, what about the lights in the stereo head unit, it seems like my top right and bottom left are the only parts that are lit up.http://volvospeed.com/vs_forum/index.php?s...hl=radio*lightsSomewhere in that thread, all the info needed is posted. It varies by year, that's all I remember. Link to comment Share on other sites More sharing options...
ACES70 Posted November 22, 2006 Report Share Posted November 22, 2006 http://volvospeed.com/vs_forum/index.php?s...hl=radio*lightsSomewhere in that thread, all the info needed is posted. It varies by year, that's all I remember.Thanks, ill sift through it and find what i need later. Link to comment Share on other sites More sharing options...
Phil94850 Posted November 23, 2006 Author Report Share Posted November 23, 2006 thanks everybody... i was scared to pry on it and break it. Link to comment Share on other sites More sharing options...
