NJGreenBudd Posted November 23, 2006 Report Share Posted November 23, 2006 hey all,My 2002 S60 has 30,000 mi on it, I just bought it in Aug and am the third owner. I have an extended warranty for this car so I want to fix this probelm.I noticed that at even moderate accelleration the tranny hesitates to shift or slips or something when it should shift,the car drives fine at cruising speed, but if you get on it to pull out onto highway or to pass it will flare up and the rpms spike before it shifts into next gear. This doesn't seem to happen all the time, the trans makes no funny noises or has any other problems, just rpm spikes sometimes when it goes to shift under accelleration. What is the problem with my car?What parts do i need to replace or how do i fix this?Thanks so much, this is my first volvo and I want to take good care of her. Have a good holiday. :huh: Link to comment Share on other sites More sharing options...
psy Posted November 23, 2006 Report Share Posted November 23, 2006 could be nothing but does your car slow down at all or bog out when you punch it or does it actually speed up then shift? if so I would say nothing because mine does that if I punch it the rpm's will go up high car is accelarting then it will shift. Link to comment Share on other sites More sharing options...
ifnt420 Posted November 23, 2006 Report Share Posted November 23, 2006 I noticed that at even moderate accelleration the tranny hesitates to shift or slips or something when it should shift,the car drives fine at cruising speed, but if you get on it to pull out onto highway or to pass it will flare up and the rpms spike before it shifts into next gear. This doesn't seem to happen all the time, the trans makes no funny noises or has any other problems, just rpm spikes sometimes when it goes to shift under accelleration.There is a new TCM SW out for the AW55 transmission. Hook your S60 up to VIDA at the dealer, and see if you have the latest SW update. Good Luck. Link to comment Share on other sites More sharing options...
NJGreenBudd Posted November 23, 2006 Author Report Share Posted November 23, 2006 There is a new TCM SW out for the AW55 transmission. Hook your S60 up to VIDA at the dealer, and see if you have the latest SW update. Good Luck.What is a TCM SW? Also whats the VIDA??Your basically saying just take it to the dealer?? Alright.Has any one else had this problem?? Link to comment Share on other sites More sharing options...
ifnt420 Posted November 23, 2006 Report Share Posted November 23, 2006 What is a TCM SW? Also whats the VIDA??Your basically saying just take it to the dealer?? Alright.Has any one else had this problem??TCM =Transmission Control Module SW = Soft wareVIDA = Vehicle Identification & Diagnostic for Aftersale (previously VADIS) Link to comment Share on other sites More sharing options...
NJGreenBudd Posted November 28, 2006 Author Report Share Posted November 28, 2006 hey inft420,Thansk for the heads up about the upgrade for the TCM, what is the DEM? I tried to search but can't search here for 3 letter words and couldn't find on net. Thanks again, i apprecciate the help with this. Take care. Link to comment Share on other sites More sharing options...
