Trooper333 Posted November 27, 2006 Report Share Posted November 27, 2006 I just purchased a 2000 V70 XC AWD SE with 48K and I want to replace all the fluids. I have two questions. 1) What components should have the fluids replaced? (I do not have the Manuals). I will be having my trusted local indy mechanic replace all the fluids so I want to have all of them ready for him. 2) Would you go with OEM Volvo fluids; or go with another product that will give better protection? It is about time to start replacing worn components. I am in the process of replacing the engine, tranny mounts and wheel bearings. I will soon be replacing the upper strut bearings, lower ball joints along with the shocks. I will be instaling the IPD sways, QuickBrick Endlinks, Cherry Turbo upper strut bar, TME Dual exhaust when I do the engine/tranny mounts.... and eventually an ECU upgrade down the road. That is all I really intend to do with the car. Thanks in advance for all your suggestions.H Link to comment Share on other sites More sharing options...
T5 phil Posted November 27, 2006 Report Share Posted November 27, 2006 I just purchased a 2000 V70 XC AWD SE with 48K and I want to replace all the fluids. I have two questions. 1) What components should have the fluids replaced? (I do not have the Manuals). I will be having my trusted local indy mechanic replace all the fluids so I want to have all of them ready for him. 2) Would you go with OEM Volvo fluids; or go with another product that will give better protection? It is about time to start replacing worn components. I am in the process of replacing the engine, tranny mounts and wheel bearings. I will soon be replacing the upper strut bearings, lower ball joints along with the shocks. I will be instaling the IPD sways, QuickBrick Endlinks, Cherry Turbo upper strut bar, TME Dual exhaust when I do the engine/tranny mounts.... and eventually an ECU upgrade down the road. That is all I really intend to do with the car. Thanks in advance for all your suggestions.Hprestone ( any kind ), brake fluid ( any kind dot 4 or more ).IPD sales a cute kit for a complete trans flush!!!I suggest synthetic oil for trans ( mobil 1 is a good choice, is not to expensive )Angle gear and rear diff have no drain plug!!!If you want replace gear oil use a suction gun. ( I suggest volvo gear oil ) ( Is not the same oil for front and rear diff ) Link to comment Share on other sites More sharing options...
