850_olaf_nz Posted November 27, 2006 Report Share Posted November 27, 2006 on the car ferry last night, the deck supervisor told me my reverse lights weren't working. that was a surprise to me!today I checked out:the fusethe bulbsand all were okay. I pulled the bulb-holders and moved them so that I could see them from the drivers area. Then I gently rocked the selector lever around in the reverse dentent (engine running, of course), and found *sometimes* my reversing lights flash... and sometimes if I held it in the right position, I could hold the reverse lamps on. Oh joy. Then, all back to 'normal' - non-functioning.So tell me - is this the dreaded PNP switch, part number - 9466012. Is there nothing else to explore - is life (for a change) that cut and dried? If so I'll source the part and get someone to install (I don't have time this week, and car due safety inspection 1 Dec). Down here, functioning reversing lights are mandatory.thanks in advance for your help!'olaf' Link to comment Share on other sites More sharing options...
AlvinL Posted November 27, 2006 Report Share Posted November 27, 2006 on the car ferry last night, the deck supervisor told me my reverse lights weren't working. that was a surprise to me!today I checked out:the fusethe bulbsand all were okay. I pulled the bulb-holders and moved them so that I could see them from the drivers area. Then I gently rocked the selector lever around in the reverse dentent (engine running, of course), and found *sometimes* my reversing lights flash... and sometimes if I held it in the right position, I could hold the reverse lamps on. Oh joy. Then, all back to 'normal' - non-functioning.So tell me - is this the dreaded PNP switch, part number - 9466012. Is there nothing else to explore - is life (for a change) that cut and dried? If so I'll source the part and get someone to install (I don't have time this week, and car due safety inspection 1 Dec). Down here, functioning reversing lights are mandatory.thanks in advance for your help!'olaf'Sound like the PNP switch is just a touch off. Try aligning the switch or adjusting it until the lights stay on when in reverse. If not maybe the switch needs to be replaced. Link to comment Share on other sites More sharing options...
FixerUpper Posted November 27, 2006 Report Share Posted November 27, 2006 pnp is the culprit x1000its not your bulbs. Link to comment Share on other sites More sharing options...
850_olaf_nz Posted November 27, 2006 Author Report Share Posted November 27, 2006 thanks, AlvinL and fixerupper. I'll look into the adjustment. I see the Haynes manual has some detail on "adjusting", although there's not a lot of useful stuff in there to be frank!best regards'olaf' Link to comment Share on other sites More sharing options...
850_olaf_nz Posted January 4, 2007 Author Report Share Posted January 4, 2007 to close this topic, it was indeed the PNP switch, replaced and now have reversing lights.Hey folks, if you follow the procedure on Bay13 - REMEMBER TO CLEAR YOUR CODES!you can align the PNP switch by eye, with care.cheers'Olaf' Link to comment Share on other sites More sharing options...
