TheBigRedCar Posted November 28, 2006 Report Share Posted November 28, 2006 In reviewing the articles in the Repair section and the Haynes manual, I come across some confusion. Are the 15mm Caliper Bracket bolts to be replaced whenever the bracket is removed? (ie: Rotor or Hub removal)The Repair articles state the bolt should be replaced when removing the hub but do not mention 15mm bolt replacement when the brake rotors are serviced. Haynes suggests replacing the bolts whenever removing the rotors.Is there a brake replacement kit with contains bolts, caps, and retaining springs?Thanks. Link to comment Share on other sites More sharing options...
Pauloil Posted November 28, 2006 Report Share Posted November 28, 2006 you get new mounting bolts with the volvo rotor from fcpgroton.I don't turn rotors, just replace them.if you need to take them off, use red locktite on the way back on Link to comment Share on other sites More sharing options...
