Phil94850 Posted November 28, 2006 Report Share Posted November 28, 2006 i asked earlier about having problems with my MBC, i forgot to mention that i have tightened my wastegate about 6 turns and with the MBC and that many turns on my wastegate im still only getting about 10psi max. any ideas ?? Link to comment Share on other sites More sharing options...
maiku Posted November 28, 2006 Report Share Posted November 28, 2006 readjust your wastegate back to stockmy guess is you're probably low on the stage 0 Link to comment Share on other sites More sharing options...
RussB Posted November 28, 2006 Report Share Posted November 28, 2006 Does the wastegate hold pressure?anywho, read this, IPD's info on wastegate adjustments Link to comment Share on other sites More sharing options...
PharmD Posted November 28, 2006 Report Share Posted November 28, 2006 Leaky hoses? How's your stage 0 looking right now? Link to comment Share on other sites More sharing options...
Phil94850 Posted November 28, 2006 Author Report Share Posted November 28, 2006 the stage 0 is good... new timing belt, plugs, wires, cap, etc., ive replaced the vac. hoses, ive checked and tightened the clamps for the hoses from the turbo to the intercooler and intake, im lost on this one...i havent checked the wastegate. i guess you have to use a vac gauge to check it ? Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted November 28, 2006 Report Share Posted November 28, 2006 you can do another test with the wastegate,pull off the hose from it and go for a test drive.but be careful the pressure normally will go very high.My opinion try it only with second gear.Otherwise there is a big risk of damaging the engine. Link to comment Share on other sites More sharing options...
Jaxx Posted November 28, 2006 Report Share Posted November 28, 2006 are you sure the MBC is hooked up right?the MBC itself might be limiting it to 10psi. Link to comment Share on other sites More sharing options...
