sion Posted November 29, 2006 Report Share Posted November 29, 2006 Hi VS'ersSome weeks ago, I fitted a boost/vac gauge to the wagon, discovered an almost invisible large split in the IAC hose in the process & was happy to observe a Park idle reading of 21 inches hot - very healthy. The car went the best it has ever gone following the hose replacement which correlated with the vacuum reading. Idling in drive, the reading was 18 inches hot.A couple of weeks later, I drove the car (wife's daily driver) and noticed idle vacuum had dropped to 17 inches in Park. Fuel consumption is up (9.5L per 100km on a long road trip last w-end), no doubt due to the ECU richening things up & idle quality is not as smooth as before - yes, I have another vac leak, but I'm damned if I can find the bugger.I've just done a full PCV service, replaced all elbows & vac lines & checked the turbo hoses. I've also removed & plugged fittings at the tree & the cruise to see if those lines are leaking. No change. For all you 850 experts, are their any other known weak spots in these systems I should be looking at? I was thinking of an under/behind dash inspection next.Thanks in advance as always. Link to comment Share on other sites More sharing options...
AlvinL Posted November 29, 2006 Report Share Posted November 29, 2006 The items that come to mind to hold vacuum.- EVAP purge valve- brake booster- CBV valve- turbo boost gauge- EGR valve- EGR vacuum control- Fuel pressur regulator (fpr)- boost control solenoidI'd disconnect the line at the source and 'suck' on it to see if it holds vacuum. That's just a simple test. Link to comment Share on other sites More sharing options...
sion Posted November 30, 2006 Author Report Share Posted November 30, 2006 Thanks Alvin.No EGR's on our spec cars, so that rules that one out. The turbo boost gauge line is also ok & I plugged the line to the canister to check that also - no change in vacuum at idle.I will investigate the evap canister more though, as I thought that may have only served as a vent/filter.On the CBV, is this a common failure & something which would drop vacuum by the 4-5 inches my engine has?Thanks you. Link to comment Share on other sites More sharing options...
