pwebb Posted December 4, 2006 Report Share Posted December 4, 2006 If anybody has more information about these codes, that would be wonderful. Currently, my heat has completely stopped working. I would like to address the problem asap!B1 Climate Control - 135 - 211 - 221 - 414 - 418Thanks! Link to comment Share on other sites More sharing options...
AlvinL Posted December 4, 2006 Report Share Posted December 4, 2006 If anybody has more information about these codes, that would be wonderful. Currently, my heat has completely stopped working. I would like to address the problem asap!B1 Climate Control - 135 - 211 - 221 - 414 - 418Thanks!1-3-5, No Engine Temp. Frequency Signal2-1-1, Driver’s Side Damper Motor Position Sensor Circuit Open Or Shorted To Power2-2-1, Pass. Side Damper Motor Position Sensor Circuit Open Or Shorted To Power4-1-4, Driver’s Side Temp. Sensor Intake Fan Seized4-1-8, No Control Signal To ECC Power Stage Link to comment Share on other sites More sharing options...
pwebb Posted December 4, 2006 Author Report Share Posted December 4, 2006 Thanks for that!now here's the problem. I swapped out my heater core not too long ago, so thats fine. the heat is hot, and my temp guage is normal. but the blower isn't working. all positions on the fan speed selector dont work. Should I try replacing the blower motor? or should I address the codes first? how would I even go about doing that? Link to comment Share on other sites More sharing options...
ACES70 Posted December 4, 2006 Report Share Posted December 4, 2006 Thanks for that!now here's the problem. I swapped out my heater core not too long ago, so thats fine. the heat is hot, and my temp guage is normal. but the blower isn't working. all positions on the fan speed selector dont work. Should I try replacing the blower motor? or should I address the codes first? how would I even go about doing that?Does your car have the automatic settings available or it a manual system? Link to comment Share on other sites More sharing options...
pwebb Posted December 4, 2006 Author Report Share Posted December 4, 2006 That would be the one. I'm assuming automatic?blower doesn't work on any setting. Link to comment Share on other sites More sharing options...
AlvinL Posted December 4, 2006 Report Share Posted December 4, 2006 Look over Bay13 and the pinned thread on useful repairs. Think you need a blower motor and power stage (resistor pack). Link to comment Share on other sites More sharing options...
tca217 Posted December 5, 2006 Report Share Posted December 5, 2006 When did the blower motor stop working? Did it make any noise or did it quit all of a sudden? Have you checked the fuses, relays, wires, ect.? Did it work BEFORE you swapped the heater core? Need more specific info to help. Link to comment Share on other sites More sharing options...
pwebb Posted December 5, 2006 Author Report Share Posted December 5, 2006 it worked before I swapped the heater core. it worked after. it made no funny noises. It just randomly decided to not want to turn on. fuses are fine. Oh, and apparently it's intermitten, because it worked for me yesterday. anybody have more info on what those codes are telling me? Link to comment Share on other sites More sharing options...
