laird Posted December 13, 2006 Report Share Posted December 13, 2006 So what kind of (total) temperature drop were you seeing? Is 250 degree F Turbo outlet temp. typical? Link to comment Share on other sites More sharing options...
narxs70 Posted December 13, 2006 Report Share Posted December 13, 2006 wow, this thread just went to the next level! thanks for the input Lucky. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted December 13, 2006 Report Share Posted December 13, 2006 The power and idle runs were done with an ECU starting in closed loop after the ECT had warmed to 80 degrees Centigrade.Was there a reason you did not use open loop for testing? That would basically remove the ECU variable. Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted December 13, 2006 Report Share Posted December 13, 2006 Was there a reason you did not use open loop for testing? That would basically remove the ECU variable.Wouldn't a closed loop be more predictable? Isn't it more fixed than dynamic?Great info Lucky. It would seem to me a more efficient intercooler is in order regardless of the intercooler plumbing you use, since most of us have ECU upgrades. Link to comment Share on other sites More sharing options...
narxs70 Posted December 13, 2006 Report Share Posted December 13, 2006 It would seem to me a more efficient intercooler is in order regardless of the intercooler plumbing you use, since most of us have ECU upgrades.truest statement of the year!!!!! Link to comment Share on other sites More sharing options...
854TGA+ Posted December 13, 2006 Report Share Posted December 13, 2006 Its not about temp its about routing. I am not sure the new routing keeps air any warmer and I highly doubt it does. What it does do is make it harder for water to reach the TBMy volvo does not cruise at 30,000 ft or have high enough intake velocities to claim phase cooling.I may be wrong but the 850 recall reguarding this replaced the throttle body not piping. Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted December 13, 2006 Report Share Posted December 13, 2006 I may be wrong but the 850 recall regarding this replaced the throttle body not piping.It was the piping not the TB. I know of dealerships with piles of these RIP kits in late '95 early '96. Link to comment Share on other sites More sharing options...
bigmay850 Posted December 14, 2006 Report Share Posted December 14, 2006 Wow what a great thread!! this really didnt have to go on this long, though it was entertaining! did we forget about chem 101, where hot less dense air rises and cooler more dense air falls, which in this case is a good thing b/c as we all know cooler more dense air is better for combustion. Link to comment Share on other sites More sharing options...
