Asinine Posted December 16, 2006 Report Share Posted December 16, 2006 I'll ask my question via a little anecdote - excuse the photos, quality was set to medium on my Nokia 6275iFirst, I woke up bright and early at 7:40 this Saturday morning (after working nights and going to bed at 3). I loaded up my Modas (17") and my housemates stockers for his SSs (18s) into the wagon - all fit no problems:Jacked up the car and test fitted the Modas, they are definitly going to look effing sick!BUT!! - ISSUE - they don't fit over the hub. I don't recall seeing R6s on 850s before, but my mechanic friend tells me the hubs on x70s and 850s are the same, and I know I've seen R6s on x70s before. Is boring out the centre normal? Anyone!?And finally, my buddy is totally a 'car guy' with a room for tires, and, only tires!!So, the centre bore!?.. anyone, bueller, anyone?!?!? Link to comment Share on other sites More sharing options...
martz0r Posted December 16, 2006 Report Share Posted December 16, 2006 Not exactly sure but dude, what size tires are those? Did they come off a truck? Link to comment Share on other sites More sharing options...
Mesoam Posted December 16, 2006 Report Share Posted December 16, 2006 there have been 850s with the modas...what size are those tires, they are absurdmight want to check the moda part num to make sure you have the same wheels... Link to comment Share on other sites More sharing options...
Patrick. Posted December 16, 2006 Report Share Posted December 16, 2006 wow that is a PS just waiting to happen.and yeah, enlarging the center bore shouldn't be too big of a hassle if u have a friend who can do it. Link to comment Share on other sites More sharing options...
Mattphi Posted December 16, 2006 Report Share Posted December 16, 2006 sweet monster truck tires! Link to comment Share on other sites More sharing options...
drin850 Posted December 16, 2006 Report Share Posted December 16, 2006 doesnt fit over the hub? i dont think its gonna fit in ur wheel well. Link to comment Share on other sites More sharing options...
850kompresser Posted December 16, 2006 Report Share Posted December 16, 2006 doesnt fit over the hub? i dont think its gonna fit in ur wheel well. sorry.. could not help myself on that one. You should be able to bore out the center without any problems.As long as you don't have to remove alot of material. They are going to look good on your car. Link to comment Share on other sites More sharing options...
exexpat Posted December 16, 2006 Report Share Posted December 16, 2006 sorry.. could not help myself on that one. You should be able to bore out the center without any problems.As long as you don't have to remove alot of material. They are going to look good on your car.Jaguar or Thunderbird/Taurus application? If I wasn't watching my 9 month old now, I would look up there center bores. Link to comment Share on other sites More sharing options...
550 Posted December 16, 2006 Report Share Posted December 16, 2006 well I cant recall what the exact size is, but kevin does know ... you just need a hub centric ring. My wheels were the same way.ddont bore the center. Link to comment Share on other sites More sharing options...
Trunks850R Posted December 16, 2006 Report Share Posted December 16, 2006 well I cant recall what the exact size is, but kevin does know ... you just need a hub centric ring. My wheels were the same way.ddont bore the center.yeah hubcentric rings will work, but are you saying the hole is too small?yeah do somethin with those tires Link to comment Share on other sites More sharing options...
Greenchunks Posted December 17, 2006 Report Share Posted December 17, 2006 Hmm, my R6's fit perfectly, on my S70, and as far as I knew they have the same center bore. You sure, they're meant fot a Volvo (correct center bore?) Link to comment Share on other sites More sharing options...
Asinine Posted December 18, 2006 Author Report Share Posted December 18, 2006 Jeremy was right, they did come off a Thunderbird. And those tires are garbage (225/55/17), no tread and will need to be replaced in the spring when they actually go on.Yes, the hole of the wheel is too small, and I will just have it bored out (no other option really) which means the wheel will no longer be hub centric and I guess there's a risk then of a shudder. Link to comment Share on other sites More sharing options...
volvo4lif3 Posted December 19, 2006 Report Share Posted December 19, 2006 my r6's came with hubcentric rings ... Link to comment Share on other sites More sharing options...
NGB Posted December 19, 2006 Report Share Posted December 19, 2006 Jeremy was right, they did come off a Thunderbird. And those tires are garbage (225/55/17), no tread and will need to be replaced in the spring when they actually go on.Yes, the hole of the wheel is too small, and I will just have it bored out (no other option really) which means the wheel will no longer be hub centric and I guess there's a risk then of a shudder.not if they are machined to the correct size.my r6's came with hubcentric rings ...The hole is too small, not too large. Link to comment Share on other sites More sharing options...
550 Posted December 19, 2006 Report Share Posted December 19, 2006 I bought my wheels and the whole was too small as well, IIRC. Still needed the rings, they just forgot to send them.. Maybe get a close up pic?There is a fine line between what one would call small and needing rings IMO. Link to comment Share on other sites More sharing options...
