USSEnterprise Posted December 19, 2006 Report Share Posted December 19, 2006 Is it possible to get a 6.5" speaker to fit in the front door of an 850, and still be able to keep the stock speaker grill? Link to comment Share on other sites More sharing options...
CAPT_BLOTTO Posted December 20, 2006 Report Share Posted December 20, 2006 youll have the cut around the door panel some its a lot of work though. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted December 20, 2006 Report Share Posted December 20, 2006 Is the stock grille even 6.5" tall? Link to comment Share on other sites More sharing options...
Owned Posted December 20, 2006 Report Share Posted December 20, 2006 Is the stock grille even 6.5" tall?No, it's 5.5 - 5.75.You could clear material in the way of the basket and magnet and then just sink a baffle in the stock local. You would lose the grille, but still get your 6.5.Or, you could just to some surgery and have part of the speaker behind the door panel. A bad location, possibly made worse.The BEST option, from a SQ POV, would be to buy a set of kicks from me. Failing that, sticking with 5.25 sounds about right until you can afford something nicer. Link to comment Share on other sites More sharing options...
paulr Posted December 20, 2006 Report Share Posted December 20, 2006 I've seen a few jobs where bigger 5.25" ande 6.5" have been hacked into the front doors, but most of them involve zipties and nasty hacking away of the door panel. What most people don't realize is, is that bass and midbass (what most people upgrade the stock locations in searc of) is just as dependent on the baffle space as it is on the driver size. You're much likely to achieve worse sound quality in the < 700Hz range by going from a properly installed medium quality 5.25" speaker to a kick-ALL GLORY TO THE HYPNOTOAD 6.5" driver held in with zipties. The waves coming off the back will cancel out the waves form the front, and viola, no volume.That being said, if you want to get into hacking the door apart, and custom fiberglass, one could probably put a thin 6.5" behind the stock grill, behind the stock mounting. However, even if this was executed properly (which would be a ton of work) it'd still be a crap location. If you're dead set on 6.5" on the doors, do down-low panels like another VS member (nucleareskimo i think) did. That or just get kicks, which if you have the money, will be much less headache. Link to comment Share on other sites More sharing options...
USSEnterprise Posted December 20, 2006 Author Report Share Posted December 20, 2006 Nevermind then. I'll just go with 5.25"s Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted December 21, 2006 Report Share Posted December 21, 2006 Nevermind then. I'll just go with 5.25"sI put infinitys in my front doors, and love the clear quality at higher volumes Link to comment Share on other sites More sharing options...
