volflo Posted July 21, 2004 Report Share Posted July 21, 2004 Hi all,i was just wondering if someone has replaced these hosesCan u replace the top oem rubber hose with a straight Samco one?If yes what inner diameter will i need?If no, is there a another comparable solution?Another question: is it worthwhile changing the two water hoses to SAMCO ones? Link to comment Share on other sites More sharing options...
Sadude Posted July 21, 2004 Report Share Posted July 21, 2004 the idea behind the samco is that it is silicon which is stronger and last much longer than the stock rubberobviously...the samco hoses instead of the normal water hoses will be better in the long run...also the waterhoses are like $100 for both of them where as the turbo hoses are like $200+ for the set Link to comment Share on other sites More sharing options...
volflo Posted July 21, 2004 Author Report Share Posted July 21, 2004 the idea behind the samco is that it is silicon which is stronger and last much longer than the stock rubberobviously...the samco hoses instead of the normal water hoses will be better in the long run...also the waterhoses are like $100 for both of them where as the turbo hoses are like $200+ for the set←thanks, i think i ll go with the water hoses, tho i think its freaking expensive for too tiny hoses.....as for the turbo hoses: since i have reversed intercooler there is no complete set. So my main question was: will I be able to use straight standard for the connection at top of intercooler, or will i face trouble because the two slight bend the oem hose has? (check pic of the hose above)edit: Forgot: Thank you, Sadude. :rolleyes: Link to comment Share on other sites More sharing options...
