wolfie00 Posted December 26, 2006 Report Share Posted December 26, 2006 So I thought I figured it out but was WRONG. Hooked up my Blitzsafe to a sc901, replacing xm commander. For the hot wire, used the yellow xm wire that had a fuse. If I even opened a window, the IPOD would pause. Start car. Pause. Then woke to dead battery this morning. Unhooked Blitzsafe. Need +12 wire. Lighter seems difficult to get too. What else near by works. Your help is appreciated. Link to comment Share on other sites More sharing options...
Guest Troy Goode Posted February 20, 2007 Report Share Posted February 20, 2007 So I thought I figured it out but was WRONG. Hooked up my Blitzsafe to a sc901, replacing xm commander. For the hot wire, used the yellow xm wire that had a fuse. If I even opened a window, the IPOD would pause. Start car. Pause. Then woke to dead battery this morning. Unhooked Blitzsafe. Need +12 wire. Lighter seems difficult to get too. What else near by works. Your help is appreciated. Link to comment Share on other sites More sharing options...
CAPT_BLOTTO Posted February 20, 2007 Report Share Posted February 20, 2007 +12v on the radio? Link to comment Share on other sites More sharing options...
Greenchunks Posted February 21, 2007 Report Share Posted February 21, 2007 swing by a local dealership service department and ask them if they can tell you which is the power wire for the deck in the wiring harness, then tap that. Mine has absolutely no issues whatsoever. Link to comment Share on other sites More sharing options...
exexpat Posted February 26, 2007 Report Share Posted February 26, 2007 swing by a local dealership service department and ask them if they can tell you which is the power wire for the deck in the wiring harness, then tap that. Mine has absolutely no issues whatsoever.+1. I vaguely recall the ignition turn-on wire being brown with a white stripe, but don't quote me on that. Get a tester and find the switched lead. Link to comment Share on other sites More sharing options...
javadoc Posted February 26, 2007 Report Share Posted February 26, 2007 +1. I vaguely recall the ignition turn-on wire being brown with a white stripe, but don't quote me on that. Get a tester and find the switched lead.I'm 99% sure you're right. It's terminal #4 of the harness going into the SC-901, all by itself actually, on that section of the harness plug. Link to comment Share on other sites More sharing options...
