Cal3thousand Posted January 7, 2007 Report Share Posted January 7, 2007 My headlights flash instead of just my parking lights. I know that I need to "isolate the switch side" with a relay.How exactly do I do that? And how/why does that work? (optional)thanks! Link to comment Share on other sites More sharing options...
b3atboxjr Posted January 9, 2007 Report Share Posted January 9, 2007 car year? model? Link to comment Share on other sites More sharing options...
PyROZen Posted January 9, 2007 Report Share Posted January 9, 2007 are you sure you have the right wire? There's separate parking light/headlight wires behind the switch so i'd retest just to be sure. The reason you have to relay isolate the parking lights (so i've been told) is because if you just flash them with a negative pulse, the doors will also unlock. I'm not sure if its true but i isolated mine on my last car just to be safe. If you can find me a picture of a standard 5-prong relay, i can tell you what to do.lee Link to comment Share on other sites More sharing options...
Cal3thousand Posted January 16, 2007 Author Report Share Posted January 16, 2007 I have a 94 850 turbo.I'll check the switch again for right wire and isolate it too. The other problem that I have is I cannot get the lock wire.I've tried several yellow/grays without success. I heard of using a relay to power the lock using the M- (yellow) wire. What do you guys think? Link to comment Share on other sites More sharing options...
PyROZen Posted January 16, 2007 Report Share Posted January 16, 2007 I have a 94 850 turbo.I'll check the switch again for right wire and isolate it too. The other problem that I have is I cannot get the lock wire.I've tried several yellow/grays without success. I heard of using a relay to power the lock using the M- (yellow) wire. What do you guys think?avoid directly interfacing with the lock motors. The wire (-lock) in my car was wayyy back in the doorboot harness and it was very difficult to get to, but it's definitly there. Definitly retest your parking lights as well, i checked tech on it and there are 2 separate wires for park/headlights.lee Link to comment Share on other sites More sharing options...
Adam Franke Posted January 16, 2007 Report Share Posted January 16, 2007 Did you tap the white wire? That's what I did and I get the same results. Link to comment Share on other sites More sharing options...
b3atboxjr Posted January 19, 2007 Report Share Posted January 19, 2007 edit: don't diode isolate like i showed here, it stops your driving lights from working while your headlights are on. sorry - that's experimentation for ya! Link to comment Share on other sites More sharing options...
b3atboxjr Posted January 22, 2007 Report Share Posted January 22, 2007 bump: read above Link to comment Share on other sites More sharing options...
Guest Guest Posted January 23, 2007 Report Share Posted January 23, 2007 thanks for the tips....i'll look into it again this weekend.Calvin Link to comment Share on other sites More sharing options...
