Guest Guest_EngTech_* Posted January 12, 2007 Report Share Posted January 12, 2007 Takes Less Time and is Way Cleaner to do , No Ramps , Get a Life ! Way Cooler and You don't have to drop the Pan and all that BS ! $44.00 at most Boat Maintance Sites ! , I did have to change the Hose Type to a Stronger one , as the Suck-tion was so Strong that It Colapsed the Hose , I picked Up a Stronger 5 ft. pc. at The Pet Store for $1.97Just did My Brand New V50 that way It got every drop of Oil , I make sure I Cut the Hose at the Bottom at an angle so It doesn'tmake a Seal on the Bottom of Crank Case - Feed it in , You can Feel when It Bottoms Out !I had to put back in 6.5 Quarts - as I made sure I Just Loosen Up the Fitler Housing a Little to break the Vacuum , this allow the NewOil Filter Housing , which are Reversed from the Old ones to Drain into the Crank Case - not on the Ground or Oil Pan ! B) Link to comment Share on other sites More sharing options...
