850GLT333 Posted July 24, 2004 Report Share Posted July 24, 2004 Today i noticed that although there are no speakers in the rear doors, they are prewired- my question is that on a 97 GLT, would the head unit be able to power two more aftermarket speakers in the rear door? (the car has premium sound sys and i believe the head unit is the SC-815 but not positive) thanks! Link to comment Share on other sites More sharing options...
maiku Posted July 25, 2004 Report Share Posted July 25, 2004 very much sojust shove any ol speaker in there..but i've read of problems because you need 8ohm speakers back there...i just put a 4ohm and its working fine with my crappy SC710 unit Link to comment Share on other sites More sharing options...
850GLT333 Posted July 25, 2004 Author Report Share Posted July 25, 2004 thanks i'll give it a try Link to comment Share on other sites More sharing options...
jleung Posted July 29, 2004 Report Share Posted July 29, 2004 Do you know what size speakers fit in the rear door? I'm considering doing the same... Link to comment Share on other sites More sharing options...
potroast Posted July 29, 2004 Report Share Posted July 29, 2004 5.25" Link to comment Share on other sites More sharing options...
Veneficus Posted July 30, 2004 Report Share Posted July 30, 2004 5.25"←5.25s don't all fit in there... I tried to put my old speakers from the front doors (5.25s) in tbe back doors and they don't fit... they're a bit larger than that. Note: I have a 97. Link to comment Share on other sites More sharing options...
maiku Posted July 30, 2004 Report Share Posted July 30, 2004 i managed to put the front door speakers into the rear door ones,they work perfectlyi got a 95 model though. don't know if that makes a differencei had to make new holes for the speaker though... Link to comment Share on other sites More sharing options...
Guest MBT Posted August 5, 2004 Report Share Posted August 5, 2004 Can someone explain to me how you got the door panels off of the rear doors? All I can find are 3 screws at the bottom of the door.Thanks,Mike. Link to comment Share on other sites More sharing options...
Veneficus Posted August 5, 2004 Report Share Posted August 5, 2004 Alright, to access the other two torx screws you have to take the arm guard on the door. Its made of the same material that you seats are... so you carefully pull that thing off as it is just a piece of cardboard that keeps the material on there, and then you have full acces to the screws. After this you must remove the door latch (black plastic thing) which can be done by pulling directly up on it. After this pull the door from the bottom and with a little force it should come off. Link to comment Share on other sites More sharing options...
steve s Posted August 6, 2004 Report Share Posted August 6, 2004 don't forget to remove the red door light at the side for rear doors.take out ur speakers and check if u have 4 ohm or 8 ohm...a sticker saying what ohm it is should be on the back of the magnet.5.25" should fit, if not, get some brackets...ur local shop may have some..online places like crutchfield may have some too. 6.5" will fit, but probably not under the stock grill and u need new holes... Link to comment Share on other sites More sharing options...
