Chilled man Posted January 16, 2007 Report Share Posted January 16, 2007 vehicle speed is aquired through the ABS module by averaging the front 2 wheel speeds, then sent to the network to the ECM, instrument cluster, ectwell since I already look like a bonehead in this thread , was there any volvo that had the speedo sensor on the transmission ? or is that the Cruise control sensor ??? I am confused at this point and time ? Link to comment Share on other sites More sharing options...
toohipsi Posted January 20, 2007 Report Share Posted January 20, 2007 If you erase the code and in time the light somes back on you can most of the time bank on a bad ABS module. The fact that you put new tires on wont set the abs light as long as the wheels and tires are the same diameter/circumference. Like someone said remove the wheels and make sure that the wheel speed sensors and exciter rings are intact, if they are then you probably have a high speed network communication problem ie:ABS Module. Hope this helps. -Matt Link to comment Share on other sites More sharing options...
