skylerwaite Posted January 23, 2007 Report Share Posted January 23, 2007 I just got my fog lights that i have been wanting forever on my 2000 s70. Originally they didn't have fog lights but there were these two unused wires that looked as if they could be for fog lights. So I tried to put them on a couple of minutes ago and they barely fit, the wires don't look as if they go in them at all, and furthermore they don't even reach the socket. I guess that means they aren't pre-wired for fogs? I'll probably spend the night crying in bed if this is the case.Any ideas? Link to comment Share on other sites More sharing options...
adamjjohn203 Posted January 24, 2007 Report Share Posted January 24, 2007 The fog perwire plugs sit behind your bumper towords the bottom on each side plugged into little clips. You my be confused with the red plugs behind your headlights....I don't know what those are for. Take pics, we'll tell you if you are on the right track Link to comment Share on other sites More sharing options...
skylerwaite Posted January 24, 2007 Author Report Share Posted January 24, 2007 Thanks a bunch! I got them plugged in but they are still having a hard time fitting. Also they don't turn on. Do I need a switch? Link to comment Share on other sites More sharing options...
adamjjohn203 Posted January 24, 2007 Report Share Posted January 24, 2007 Yes you need a switch and a "J" relay. Usually you can find them both on ebay. I'll see what I ca find for you. Link to comment Share on other sites More sharing options...
AaronD81 Posted January 24, 2007 Report Share Posted January 24, 2007 The directions are on here somewhere, that's how I installed mine. You need the switch, a relay that goes under the dash, and also a jumper wire that plugs into another relay hole under the dash. Depending on how you plug in the jumper wire determines how the fog lights turn on. Link to comment Share on other sites More sharing options...
adamjjohn203 Posted January 24, 2007 Report Share Posted January 24, 2007 The 2000's don't need jumpers! That's why I hav an extra jumper in my office! :huh: Link to comment Share on other sites More sharing options...
adamjjohn203 Posted January 24, 2007 Report Share Posted January 24, 2007 Also make sure you get the front fog switch w/ the little light in the picture facing to the left. Link to comment Share on other sites More sharing options...
JDELUNA Posted January 24, 2007 Report Share Posted January 24, 2007 Can't remember if there is a FUSE for the foglights, if there is maybe you need one ?? Hope this helps. God Bless :) Link to comment Share on other sites More sharing options...
skylerwaite Posted January 24, 2007 Author Report Share Posted January 24, 2007 Thank you, Adam! You seriously kick jerk.Oh nice edit message board. I meant kick @ss. Link to comment Share on other sites More sharing options...
Guest Guest Posted January 27, 2007 Report Share Posted January 27, 2007 So all s/v70's are prewired for fogs? Link to comment Share on other sites More sharing options...
adamjjohn203 Posted January 27, 2007 Report Share Posted January 27, 2007 I don't know....maybe. Look for yourself. There should be plugs behind the bumper and a plug for the switch next to the rear fog button. Link to comment Share on other sites More sharing options...
skylerwaite Posted January 27, 2007 Author Report Share Posted January 27, 2007 OK, so I have the relay and switch on the way now. Where do I put the relay? Link to comment Share on other sites More sharing options...
adamjjohn203 Posted January 27, 2007 Report Share Posted January 27, 2007 Under the dash pull off the lower panel above the pedals. above the brake and to the left in the back there is a relay panel. The upper left spot labeled 201 is where it easily slides into. I found a pdf file for installation instructions in these forums once can't find it yet. Link to comment Share on other sites More sharing options...
maiku Posted January 29, 2007 Report Share Posted January 29, 2007 my S70 was prewired for fogsjust needed the two relays and switchdamn simple install (but kit cost like 200 bucks from dealership)now, i'm not sure about this, but i thought 99-00 needed ECU activation for fogsor was that just S40's? Link to comment Share on other sites More sharing options...
adamjjohn203 Posted January 29, 2007 Report Share Posted January 29, 2007 Nope...like I said only one relay (J) and a switch, 99-00 models don't even use the 213 jumper (no foglight mod). That's it! I just did it last week. Link to comment Share on other sites More sharing options...
