19t Without Remapping
volflo
as some might know i run a bsr chip mapped for the 16T.
my car runs very nicely so far. I was actually thinking of swapping to a 19T and keeping the rest as it is.
so keep the injectors and keep the fuel pressure. i dont actually want ot go higher than my current boost (19 psi, 1.3 bar that i have betwenn 3800 and ~4700)
Anyway, with the 19T im hoping on keeping those 19psi from lets say 3800 rpm to as close i can go to redline with those parameters.
what do you think? Stupid plan? Or is worth the effort when i basically just change the 16T to 19T and rest stays the same.....
  • Replies 30
Volflo
You could use the 19T with the same settings but I think you will end up a bit slower compared to the 16T. Also the 19T will start earlier and doesn't drop off boost as soon as the 16T. Specially this last area might cause your engine to run lean. The only way to know is to put the 19T on and do some A/F measuring.
I would strongly advice you to install the 350 CC. The 315 CC just don't cut it, asking for trouble.
Volflo
What does the 350CC injector come from? Mine has those...
~Lee
thanks very much for all the decent help.
could someone just sum up what injectors have
-what capacity and what flow?
-what color?
excel sheet?? ;)
1. i think along with the 19T i will also get the (blue?) injectors of the 2000 265hp v70R. will those be alright?
2. (and another question: did my 96 R manual (came with 16t from factory, b5234t4) come with bigger injectors already?)
3. i still have a third option: i can get hold of a used engine. This one:
16T - B5234T3 240hp 1997-1998 finns i S/V/C70 T5, straight oulet from turbine.
what kind of injectors does that one have?
which of the three injector options is best?
-what color?
excel sheet??  ;)
Here is a fourth option: ask Rob @ VMS.
Look @ link:
http://forums.vptuning.com/viewtopic.php?t=4223&highlight=
"Here is a fourth option: ask Rob @ VMS.
Look @ link:
http://forums.vptuning.com/viewtopic.php?t=4223&highlight "
this thread like tuning itself: in the beginninge i just wanted to swap my 16t to 19T, just a tiny bit later i end up with a custum fuel pump, huge custom injectors..... :lol:
no, honestly, that goes a bit too far. (at least for now, but never say never) :lol:
-what color?
excel sheet??  ;)
Option 3 has white injectors (350cc)
The blue injectors are 395 cc, but there should also be green injectors 475 cc.
I'd say (moneywise) go for the blue's get the @ recycle place (I don't think you'll find the green ones there).
