trance42 Posted February 12, 2007 Report Share Posted February 12, 2007 None of my gauges work. If the trip comp goes out will it cause all the gauges to stop working? Is there a relay for all the gauges? Haynes manual has fuse numbers for tack speed fuel and coolant temp but they didn't include it in any of the diagrams. I cant seem to find it in the factory manual that someone posted a link for a while back.ANY INFO IS GREATLY APPRECIATED.Tim Link to comment Share on other sites More sharing options...
matt b Posted February 12, 2007 Report Share Posted February 12, 2007 If the trip comp goes out will it cause all the gauges to stop working?Not if it's a mechanical trip computer on a P1 car. Link to comment Share on other sites More sharing options...
trance42 Posted February 12, 2007 Author Report Share Posted February 12, 2007 Not if it's a mechanical trip computer on a P1 car.95 850 turbo Link to comment Share on other sites More sharing options...
matt b Posted February 12, 2007 Report Share Posted February 12, 2007 95 850 turboCheck fuses under hood, on driver's side. Your trip computer failing is linked to an odometer gear and is a mechanical issue that should not cause your cluster to fail. BTW: an odometer gear repair is $25 and 20 minutes of your time. It's worth it! Link to comment Share on other sites More sharing options...
trance42 Posted February 12, 2007 Author Report Share Posted February 12, 2007 i don't think its mechanical it happened when my wiring harness caught fire. everything is in working order now except gauges. i have replaced a bunch of relays. Link to comment Share on other sites More sharing options...
trance42 Posted February 13, 2007 Author Report Share Posted February 13, 2007 has anyone had any problem with there gauges Link to comment Share on other sites More sharing options...
Pauloil Posted February 13, 2007 Report Share Posted February 13, 2007 I think some wires got fried, as it were. shorts can happen heat damages. Link to comment Share on other sites More sharing options...
BEJinFBK Posted February 13, 2007 Report Share Posted February 13, 2007 i don't think its mechanical it happened when my wiring harness caught fire. everything is in working order now except gauges. i have replaced a bunch of relays.Sounds like you need to replace the damaged harness and THEN start troubleshooting...You might want to hang on to the fried harness for a little while. It may help you figure things out. Link to comment Share on other sites More sharing options...
matt b Posted February 13, 2007 Report Share Posted February 13, 2007 Sounds like you need to replace the damaged harness and THEN start troubleshooting...You might want to hang on to the fried harness for a little while. It may help you figure things out.And it would have helped me to know this in your 1st post. Fires and electrical wires don't get along. Link to comment Share on other sites More sharing options...
trance42 Posted February 14, 2007 Author Report Share Posted February 14, 2007 I have replaced the engine wiring harness. I have replaced a bunch of relays. I have replaced the ECU.None of the fuses were blown when it shorted. Everything works except the gauges. Some of the lights in the gauges were burnt out. The trip computer scrambles but then goes to the clock. Link to comment Share on other sites More sharing options...
trance42 Posted February 14, 2007 Author Report Share Posted February 14, 2007 And it would have helped me to know this in your 1st post. Fires and electrical wires don't get along.Well for anyone who does a manual swap make sure your clutch fork is not rubbing the harness.I routed the harness away from the clutch fork but when i took it to a shop they put a zip tie on it and pulled it closer to the fork.Over time the fork rubbed the coating off a 12v wire. Link to comment Share on other sites More sharing options...
