oddferkout Posted February 17, 2007 Report Share Posted February 17, 2007 "Time for Regular Maintenance"How do I get rid of the message on the info screen and seeing that it's the first time this message has come up, should I take it into the dealer or what? Link to comment Share on other sites More sharing options...
Fisher Posted February 17, 2007 Report Share Posted February 17, 2007 "Time for Regular Maintenance"How do I get rid of the message on the info screen and seeing that it's the first time this message has come up, should I take it into the dealer or what?Just means its time for an oil change. If you are going to take it to the dealer for the oil change, then they will reset for you. If not, you can try one of the methods that is posted in the archives. IIRC, it has something to do with holding the trip reset button while turning the ignition key on. You'll have to search to be sure. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted February 17, 2007 Report Share Posted February 17, 2007 Turn key to position one, press and hold trip odo button, turn key to position 2 and continue to hold button until the "I" flashes.That is basically a timer set to go off every 7500 miles or 6 months. Link to comment Share on other sites More sharing options...
oddferkout Posted February 18, 2007 Author Report Share Posted February 18, 2007 Turn key to position one, press and hold trip odo button, turn key to position 2 and continue to hold button until the "I" flashes.That is basically a timer set to go off every 7500 miles or 6 months.Thanks! That's what I figured at first about the 7500 mile thing. I'm big on oil changes every 3k so I wasn't too alarmed. Link to comment Share on other sites More sharing options...
