smokin' T5M Posted March 2, 2007 Author Report Share Posted March 2, 2007 PS. If it matters, get a set made and check resistance over length? maybe builder will test a set for us? T.Here's a brief synopsis of the resistance of wire wound (Mag Wire) conductors. The conductor is a copper / nickel alloy (solid metal) spherically wrapped around strands of Kevlar. It is then coated with a latex (which is also conductive) that helps to hold the windings in place. With this type of wire the resistance is consistent regardless of the length of the wire. The wire we are using is 100 ohms per foot (+ or - 10%). You are getting differing measurements because you are reading through the latex which is 3000 to 7000 ohms per foot. For our lab testing procedures we use a frequency generator to apply the equivalent of 40,000 volts to our test wires. This "burns" through the latex and resistance settles at 100 ohms per foot. In your case, if you put them on the car and started the engine the same thing would take place within a few minutes. This issue often comes up when a tech "tests" the wires before installing them. With carbon core wires (no wire winding) the resistance would measure 3000 to 7000 ohms per foot. Mag wire can measure the same as the carbon wires before they are installed because of reading through the latex. Hope this makes sense .This info is straight form the horses mouth. Link to comment Share on other sites More sharing options...
1997850T5R Posted March 2, 2007 Report Share Posted March 2, 2007 1. TM850R - RED2. tanker - RED3. rexford310 - BLUE4. jarediii - RED5. Eric - RED6. Dave - Blue7. ET - RED8. flyfishing3(mike)-Red9. wmartinlsmith - Blue10. 1997850T5R - Blue11. NW T5R - Blue 8.5mm12. Zip-N-By - Red13. Robert - 5 sets of each color 15 sets total****14. Danpeal - Blue15. Helodrv - Red16. 8G5L0T <<FLORIDUH! Add your colors!17. Mattphi <<Got any kind of time frame yet? Just curious. Link to comment Share on other sites More sharing options...
Pops Racer Posted March 2, 2007 Report Share Posted March 2, 2007 Here's a brief synopsis of the resistance of wire wound (Mag Wire) conductors. The conductor is a copper / nickel alloy (solid metal) spherically wrapped around strands of Kevlar. It is then coated with a latex (which is also conductive) that helps to hold the windings in place. With this type of wire the resistance is consistent regardless of the length of the wire. The wire we are using is 100 ohms per foot (+ or - 10%). You are getting differing measurements because you are reading through the latex which is 3000 to 7000 ohms per foot. For our lab testing procedures we use a frequency generator to apply the equivalent of 40,000 volts to our test wires. This "burns" through the latex and resistance settles at 100 ohms per foot. In your case, if you put them on the car and started the engine the same thing would take place within a few minutes. This issue often comes up when a tech "tests" the wires before installing them. With carbon core wires (no wire winding) the resistance would measure 3000 to 7000 ohms per foot. Mag wire can measure the same as the carbon wires before they are installed because of reading through the latex. Hope this makes sense .This info is straight form the horses mouth.awesome job on the test data. T. Link to comment Share on other sites More sharing options...
smokin' T5M Posted March 2, 2007 Author Report Share Posted March 2, 2007 1. TM850R - RED2. tanker - RED3. rexford310 - BLUE4. jarediii - RED5. Eric - RED6. Dave - Blue7. ET - RED8. flyfishing3(mike)-Red9. wmartinlsmith - Blue10. 1997850T5R - Blue11. NW T5R - Blue12. Zip-N-By - Red13. Robert - 5 sets of each color 15 sets total****14. Danpeal - Blue15. Helodrv - Red16. 8G5L0T <<FLORIDUH! Add your colors!17. Mattphi - Red Link to comment Share on other sites More sharing options...
8G5L0T Posted March 3, 2007 Report Share Posted March 3, 2007 1. TM850R - RED2. tanker - RED3. rexford310 - BLUE4. jarediii - RED5. Eric - RED6. Dave - Blue7. ET - RED8. flyfishing3(mike)-Red9. wmartinlsmith - Blue10. 1997850T5R - Blue11. NW T5R - Blue12. Zip-N-By - Red13. Robert - 5 sets of each color 15 sets total****14. Danpeal - Blue15. Helodrv - Red16. 8G5L0T - Red17. Mattphi - Red Link to comment Share on other sites More sharing options...
smokin' T5M Posted March 3, 2007 Author Report Share Posted March 3, 2007 1. TM850R - RED2. tanker - RED3. rexford310 - BLUE4. jarediii - RED5. Eric - RED6. Dave - Blue7. ET - RED8. flyfishing3(mike)-Red9. wmartinlsmith - Blue10. 1997850T5R - Blue11. NW T5R - Blue12. Zip-N-By - Red13. Robert - 5 sets of each color 15 sets total****14. Danpeal - Blue15. Helodrv - Red16. 8G5L0T - Red17. Mattphi - Red 18. Fredo - BlueThings are looking good keep it up. Link to comment Share on other sites More sharing options...
drin850 Posted March 4, 2007 Report Share Posted March 4, 2007 whens the deadline for this GB? Link to comment Share on other sites More sharing options...
Jesus Posted March 4, 2007 Report Share Posted March 4, 2007 Visited Tim and shot a few pictures of the wires. The ones that aren't bright yellow are OEM. Link to comment Share on other sites More sharing options...
TM850R Posted March 4, 2007 Report Share Posted March 4, 2007 Works good for me. Link to comment Share on other sites More sharing options...
Mattphi Posted March 4, 2007 Report Share Posted March 4, 2007 whens the deadline for this GB?I believe you have a couple weeks at the most. I know its comming down to the wire for putting orders in Link to comment Share on other sites More sharing options...
Pops Racer Posted March 4, 2007 Report Share Posted March 4, 2007 Visited Tim and shot a few pictures of the wires. The ones that aren't bright yellow are OEM.Beauty! :tup: Link to comment Share on other sites More sharing options...
rexford310 Posted March 4, 2007 Report Share Posted March 4, 2007 eww yellow just kidding they look good enough to eat :wub: Link to comment Share on other sites More sharing options...
NW T5R Posted March 5, 2007 Report Share Posted March 5, 2007 Looks great,Let us know when to send funds Link to comment Share on other sites More sharing options...
Plan_B Posted March 5, 2007 Report Share Posted March 5, 2007 eww yellow :) Link to comment Share on other sites More sharing options...
TM850R Posted March 9, 2007 Report Share Posted March 9, 2007 Curious as to how this is coming along. Link to comment Share on other sites More sharing options...
