Hilton Posted February 23, 2007 Report Share Posted February 23, 2007 I would really like a new cam cover/retainer. I had mine powdercoated blue and I am not happy with the way that it turned out. It's off right now anyway, so I could buy another one and stick it on instead.I know someone's got one on a shelf. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted February 24, 2007 Report Share Posted February 24, 2007 They are typically machined together and are not meant to be swapped out. But if you are willing to give it a try I might be willing to part with the one I have for the right price. It's off of a 95 NA Link to comment Share on other sites More sharing options...
Hilton Posted February 24, 2007 Author Report Share Posted February 24, 2007 I got one coming. Thanks. Hoping for the best. Link to comment Share on other sites More sharing options...
BlackT5 Posted February 25, 2007 Report Share Posted February 25, 2007 Hope it doesn't cause your cams to bind up. Could be a whole lot of trouble to get rid of your colored cam cover.Can't you strip the powder coat off? Link to comment Share on other sites More sharing options...
Keaton85 Posted February 25, 2007 Report Share Posted February 25, 2007 The head and the cam cover are made to fit as one... i wouldnt get a used one and install it or you are going to have a whole lot of trouble at hand.. Link to comment Share on other sites More sharing options...
Scootdiggity Posted February 25, 2007 Report Share Posted February 25, 2007 The head and the cam cover are made to fit as one... i wouldnt get a used one and install it or you are going to have a whole lot of trouble at hand..I sent him a pm when he first listed the want ad that it was a bad idea but he did not believe me that the cam and head are cast as one unit and arent interchangeable. I have read too many threads on message boards about people who have switched them and it all ended in engine failure, but people learn by their own mistakes. Link to comment Share on other sites More sharing options...
Keaton85 Posted February 25, 2007 Report Share Posted February 25, 2007 I sent him a pm when he first listed the want ad that it was a bad idea but he did not believe me that the cam and head are cast as one unit and arent interchangeable. I have read too many threads on message boards about people who have switched them and it all ended in engine failure, but people learn by their own mistakes.This is why people have to be very very carful when they do any type of head work becuase if you mess the cover up by cracking it then you are looking at a new head. If you look at how the head is cast you wouldnt be able to get a uniform cast in every head where the cams ride. I think that covers it... Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted February 26, 2007 Report Share Posted February 26, 2007 Well this means I get to keep mine as a wall display piece. I love it!! Link to comment Share on other sites More sharing options...
Gioseppe Posted February 26, 2007 Report Share Posted February 26, 2007 lol.yes, they are a matched set. when the factory line bored the cam journals they become matched. it would be possible to re line-bore a new cover to match (i already went over this with my machinist) but it's a hassle.buuuut certainly don't swap a different one on there without doing any machine work! i pulled the cam cover off the engine of mine that got toasted andthe cam journals were severly scored from the fit being too tight. Link to comment Share on other sites More sharing options...
TEKVOLVO Posted February 27, 2007 Report Share Posted February 27, 2007 lol.yes, they are a matched set. when the factory line bored the cam journals they become matched. it would be possible to re line-bore a new cover to match (i already went over this with my machinist) but it's a hassle.buuuut certainly don't swap a different one on there without doing any machine work! i pulled the cam cover off the engine of mine that got toasted andthe cam journals were severly scored from the fit being too tight.I have swapped one out and later removed it to find the same thing, however, had no engine problems. But I woulden't suggest it. Some covers may just be a closer fit, depending on the batch when it was made. But what are the chances of getting a used one made in the same batch? Might want to have the powder coat sand blasted. Link to comment Share on other sites More sharing options...
