sox2112 Posted February 24, 2007 Report Share Posted February 24, 2007 i did a search and couldn't find much info other then for the dynaudio system. i have a c70 coupe w/ the sc-816 hu. from previous posts i have come up w/ these speaker sizes:1 inch tweets on the dash and rear deck4" speakers on the top part of doors8" woofers(mid bass/mid range) on the bottom part of the doors 6.5" speakers on the rear deck does this sound correct? also i have a 4 channel amp...i will use that to power the 4 speakersi have a 2 channel amp for the 8" woofersbut do i have to run tweets to an amp or can i just put new ones in and leave the connection alone?also can i hook up amps to the sc-816?i wanna get speakers in the next day or so...so any help would be great Link to comment Share on other sites More sharing options...
sox2112 Posted February 25, 2007 Author Report Share Posted February 25, 2007 29 views and no response? Link to comment Share on other sites More sharing options...
exexpat Posted February 26, 2007 Report Share Posted February 26, 2007 So you don't have the factory 9" subs? Mine are 5" center, 8.5" door woofers, 4" door mids, 1" dash tweeters, 6.5" rears, 9" subs + ahhed JL 10" sub i did a search and couldn't find much info other then for the dynaudio system. i have a c70 coupe w/ the sc-816 hu. from previous posts i have come up w/ these speaker sizes:1 inch tweets on the dash and rear deck4" speakers on the top part of doors8" woofers(mid bass/mid range) on the bottom part of the doors 6.5" speakers on the rear deck does this sound correct? also i have a 4 channel amp...i will use that to power the 4 speakersi have a 2 channel amp for the 8" woofersbut do i have to run tweets to an amp or can i just put new ones in and leave the connection alone?also can i hook up amps to the sc-816?i wanna get speakers in the next day or so...so any help would be great Link to comment Share on other sites More sharing options...
sox2112 Posted February 26, 2007 Author Report Share Posted February 26, 2007 So you don't have the factory 9" subs? Mine are 5" center, 8.5" door woofers, 4" door mids, 1" dash tweeters, 6.5" rears, 9" subs + ahhed JL 10" sub i dont have the pro-logic setup (no center channel) where would the subs be? i look in my trunk at the speakers in the rear deck...it looks like i have a speaker and a tweet in the rear deck. are you sure the door woofers aren't just 8"? Link to comment Share on other sites More sharing options...
sox2112 Posted February 26, 2007 Author Report Share Posted February 26, 2007 here's my prospective system:dash- boston acoustics neo type-s 1" tweetsupper door- boston acoustics s45 4" lower door- kicker 04SSMB8 8" midbassrear deck/tweets- boston acoustics sx60 6.5" & 1" tweetshu- eclipse avn55104 ch rockford fosgate amp for speakers2 ch rockford fosgate amp for midbasshows it look? Link to comment Share on other sites More sharing options...
exexpat Posted February 26, 2007 Report Share Posted February 26, 2007 Front door woofers are larger than a standard 8". You can get 8" to work, you'll just be positioning the driver with the screws along the outer frame of the woofer, versus using the woofer mounting holes. The rear 9" woofers oddly are the same - slightly bigger than an aftermarket (usually Morel) 9".here's my prospective system:dash- boston acoustics neo type-s 1" tweetsupper door- boston acoustics s45 4" lower door- kicker 04SSMB8 8" midbassrear deck/tweets- boston acoustics sx60 6.5" & 1" tweetshu- eclipse avn55104 ch rockford fosgate amp for speakers2 ch rockford fosgate amp for midbasshows it look?Sounds good. I also have SSMB 8's :) Link to comment Share on other sites More sharing options...
TH1RT3EN628 Posted March 7, 2007 Report Share Posted March 7, 2007 how much does all that cost? Link to comment Share on other sites More sharing options...
sox2112 Posted March 9, 2007 Author Report Share Posted March 9, 2007 how much does all that cost?i priced it out the other day but lost the piece of paper...probably around $400 for the speakers (ebay or some other online car audio store) and i already own the 2 amps. the eclipse avn 5510 is like $1100 or so Link to comment Share on other sites More sharing options...
