Socal Posted February 24, 2007 Report Share Posted February 24, 2007 I was poking around under the car, looking at my front engine mount, and I happended to notice what I thought was some gunk on my crank pully. It turned out to be a finger width long bite out of the pully... Should I be worried about this chewing the timing belt up? Link to comment Share on other sites More sharing options...
caliwagon Posted February 24, 2007 Report Share Posted February 24, 2007 ...Would only affect the serp. belt, not the t-belt. I wouldn't worry about it--just change your s-belt at the regular intervals Link to comment Share on other sites More sharing options...
Socal Posted February 24, 2007 Author Report Share Posted February 24, 2007 dur... I remember thinging about how odd it was that t-belt was routed towards the front of the car where the accessory pullys are, but nothing in my head put it together. Anyway, I guess that allays my fear of catastrophic timing belt failure.None the less, what the hell? How do you so neatly take a chunk out like that? Link to comment Share on other sites More sharing options...
prasamin Posted February 25, 2007 Report Share Posted February 25, 2007 something may have gotten lodged in there for a second and taken a chunk out. not much to worry about with the serp belt, although that point may help wear it out more quickly, so make sure you inspect it regularly and change it when needed. Link to comment Share on other sites More sharing options...
Mesoam Posted February 25, 2007 Report Share Posted February 25, 2007 that bend looks like it has a sharp edge on it...if your serp belt breaks your car doesn't run, well it should for a little while till your battery diesi'de say look for a replacement, one shouldn't be too expensive as people are rarely looking for them Link to comment Share on other sites More sharing options...
MadeInJapan Posted February 25, 2007 Report Share Posted February 25, 2007 I'd say the mechanic who did a TB change before, trying to get the belt over that crank pulley did it. No way a belt or even a small amount of debris could do that. At the very least I would try to get the sharp edge off of it. Link to comment Share on other sites More sharing options...
matt b Posted February 25, 2007 Report Share Posted February 25, 2007 I'd say the mechanic who did a TB change before, trying to get the belt over that crank pulley did it. No way a belt or even a small amount of debris could do that. At the very least I would try to get the sharp edge off of it.File it down, change your belt ($23-$25) and be done with it...Having a serpentine belt break on you isn't fun, why take the risk when it's such an easy fix. Link to comment Share on other sites More sharing options...
