BlackBeast Posted February 25, 2007 Report Share Posted February 25, 2007 I have a '97 V70 T5M, i want a volvo rad that has no other coolers built in. I asume that I need the N/A version for that?So which is the best rad to get from Volvo? Engine codes? Do the p2s fit straight on? Im sure i read a while back Johann used a '01 rad in his '99? Link to comment Share on other sites More sharing options...
Keaton85 Posted February 25, 2007 Report Share Posted February 25, 2007 I have a '97 V70 T5M, i want a volvo rad that has no other coolers built in. I asume that I need the N/A version for that?So which is the best rad to get from Volvo? Engine codes? Do the p2s fit straight on? Im sure i read a while back Johann used a '01 rad in his '99?Why do you need one without oil cooler fittings? they realy dont take up any space at all. If you get an N/A rad. then you will still have the auto tranny cooler fittings. Link to comment Share on other sites More sharing options...
BlackBeast Posted February 25, 2007 Author Report Share Posted February 25, 2007 Im in the UK, equal amounts of manual and auto box volvos here I shall be fitting a mocal oil cooler hence why i dont want the rad with any other coolers. Please, dont want any noobs or pras telling me i dont need a seperate oil cooler!Anyone know which rad i need? Link to comment Share on other sites More sharing options...
prasamin Posted February 25, 2007 Report Share Posted February 25, 2007 Im in the UK, equal amounts of manual and auto box volvos here I shall be fitting a mocal oil cooler hence why i dont want the rad with any other coolers. Please, dont want any noobs or pras telling me i dont need a seperate oil cooler!Anyone know which rad i need?I wont tell you that you dont need an oil cooler, but I'll tell you that all you have to do is drain the coolers on your rad, plug them, and add an oil cooler. There were some volvos with tow packages that came with an aux trans cooler. you can, of course, use these as an aux oil cooler. Link to comment Share on other sites More sharing options...
BlackBeast Posted February 25, 2007 Author Report Share Posted February 25, 2007 Sorry pras, i did forget a at the end of the second paragraph.Thanks for the info though, i know i could plug the rad I have now, but i just want to start again with a fresh base so to speak, which means a nice new fresh rad. Link to comment Share on other sites More sharing options...
prasamin Posted February 25, 2007 Report Share Posted February 25, 2007 Sorry pras, i did forget a at the end of the second paragraph.Thanks for the info though, i know i could plug the rad I have now, but i just want to start again with a fresh base so to speak, which means a nice new fresh rad.so what you need to do is get an OEM 850 turbo MANUAL radiator....it only comes with 1 set of cooler ports for the oil....use that for your auto trans (i think that's what you have), and then run the other two lines to the aux cooler for the oil.although, i recommend cooling your trans fluid before your oilthe BEST idea would be to get a stock auto radiator, use both coolers on it for the oil, and get an aux FMTC to run your trans lines to. Link to comment Share on other sites More sharing options...
Keaton85 Posted February 25, 2007 Report Share Posted February 25, 2007 so what you need to do is get an OEM 850 turbo MANUAL radiator....it only comes with 1 set of cooler ports for the oil....use that for your auto trans (i think that's what you have), and then run the other two lines to the aux cooler for the oil.although, i recommend cooling your trans fluid before your oilthe BEST idea would be to get a stock auto radiator, use both coolers on it for the oil, and get an aux FMTC to run your trans lines to.T5M.... why are you bothering anyway? Link to comment Share on other sites More sharing options...
Johann Posted February 25, 2007 Report Share Posted February 25, 2007 I have a '97 V70 T5M, i want a volvo rad that has no other coolers built in. I asume that I need the N/A version for that?So which is the best rad to get from Volvo? Engine codes? Do the p2s fit straight on? Im sure i read a while back Johann used a '01 rad in his '99?'99 and up manual T5 radiator comes without extra coolers. There is a connection on top of the radiator for the expansion tank though, need to block that if you want to install on an 850. Link to comment Share on other sites More sharing options...
BlackBeast Posted February 25, 2007 Author Report Share Posted February 25, 2007 '99 and up manual T5 radiator comes without extra coolers. There is a connection on top of the radiator for the expansion tank though, need to block that if you want to install on an 850.Thank you Johann. Would these rads have exactly the same mounting positions as an 850/early x70s? What would be the best way to block that connection?Last question, are there any 850/pre ME7 x70s that you know of that come without extra coolers? Link to comment Share on other sites More sharing options...
Johann Posted February 25, 2007 Report Share Posted February 25, 2007 Thank you Johann. Would these rads have exactly the same mounting positions as an 850/early x70s? What would be the best way to block that connection?Last question, are there any 850/pre ME7 x70s that you know of that come without extra coolers?The only one that I can think of are the early NA MT versions. The NA 850 I have here, SDM which was '92 AT, uses a cooler for the AT but doesn't have the oil cooler like the turbo engine's.The S70 radiator is same size as the older models. You could block it using a small piece of hose and a plug made out of alloy or so. Two hose clamps and it should be OK. Link to comment Share on other sites More sharing options...
Keaton85 Posted February 25, 2007 Report Share Posted February 25, 2007 why are we talking about blocking off the holes anyway? and is there any size difference between the rads with both oil coolers and ones without? i dont think so but i might be wrong. Link to comment Share on other sites More sharing options...
Johann Posted February 25, 2007 Report Share Posted February 25, 2007 why are we talking about blocking off the holes anyway?On the older engine's there is a vent hose connection on top of the thermostat housing which vents to the coolant expansion tank.On the newer models this connection has been moved to the top of the radiator. Link to comment Share on other sites More sharing options...
BlackBeast Posted February 25, 2007 Author Report Share Posted February 25, 2007 On the older engine's there is a vent hose connection on top of the thermostat housing which vents to the coolant expansion tank.On the newer models this connection has been moved to the top of the radiator.Which is better? Could I change the thermostat housing to the newer style one without the vent? Link to comment Share on other sites More sharing options...
Johann Posted February 25, 2007 Report Share Posted February 25, 2007 Which is better? Could I change the thermostat housing to the newer style one without the vent?I think you can but why would you? Link to comment Share on other sites More sharing options...
BlackBeast Posted February 25, 2007 Author Report Share Posted February 25, 2007 I think you can but why would you?Would be pointless having two vents, so if I was to get the newer style rad I might aswell use the vent that came with it, dont you think? Thats all id have to do is find a thermo housing from an ME7 in the scrap yard. Link to comment Share on other sites More sharing options...
