sion Posted March 4, 2007 Report Share Posted March 4, 2007 Hello allAs the topic says, I'm about to pop the trans back in after doing the RMS & other important seals & need the torque settings for the flexplate bolts.Also, what is recommended for the bolts - Loctite or thread sealer, as the bolt ends are exposed to the crankcase, hence oil.Many thanks. Link to comment Share on other sites More sharing options...
Keaton85 Posted March 5, 2007 Report Share Posted March 5, 2007 Hello allAs the topic says, I'm about to pop the trans back in after doing the RMS & other important seals & need the torque settings for the flexplate bolts.Also, what is recommended for the bolts - Loctite or thread sealer, as the bolt ends are exposed to the crankcase, hence oil.Many thanks.I use loctite then zap it with the cordless impact gun so idono the true specs... but you will be fine with loctite... Link to comment Share on other sites More sharing options...
sion Posted March 5, 2007 Author Report Share Posted March 5, 2007 I use loctite then zap it with the cordless impact gun so idono the true specs... but you will be fine with loctite...Thanks for that. I just found out it is 45NM + 50 degrees. I just love these torque specs where degrees are involved... :D Link to comment Share on other sites More sharing options...
Keaton85 Posted March 5, 2007 Report Share Posted March 5, 2007 Thanks for that. I just found out it is 45NM + 50 degrees. I just love these torque specs where degrees are involved... yeah degrees are a PITA... its going to be even harder on a flat surface. I wouldnt bother with those specs, just get them nice and tight... i havnt had any trouble on any of the jobs ive done.. Link to comment Share on other sites More sharing options...
