TheMan5952 Posted March 10, 2007 Author Report Share Posted March 10, 2007 Just got back, they re-did it with 7 more quarts and it looks alot better. Now I just need to do my brakes. Link to comment Share on other sites More sharing options...
FredMc Posted March 11, 2007 Report Share Posted March 11, 2007 If the VADIS directions for doing a flush through the coolant lines are followed the process begins by first draining & filing the the pan, so it is actually not a "flush only through the coolant lines.". Billtotally correct. If you want to really do it the unquestionably correct way, then as he stated above.You drain away sediment and crud from the pan, and then flush out with fresh fluid the rest.Just make sure you use the correct fluid. Link to comment Share on other sites More sharing options...
