volvolove Posted August 3, 2004 Report Share Posted August 3, 2004 I'm just curious because I've forgottten: What is the reason behind replacing the stock wastegate actuator with the 300/70 one you guys like? Link to comment Share on other sites More sharing options...
turbor850 Posted August 3, 2004 Report Share Posted August 3, 2004 the 15G 150/?0 isn't good for holding boost at higher rpms, which everyone kinda knowsthe 300/70 wastegate on the 19T and maybe 18T holds boost a lot better at higher rpms . . . Link to comment Share on other sites More sharing options...
swdracr Posted August 3, 2004 Report Share Posted August 3, 2004 It didn't help me hold boost at higher RPMs at all; the limit there is the turbo, not the wastegate. What it did do was allow me to run higher boost without using a MBC. It just has a stiffer spring than the 150/40. Link to comment Share on other sites More sharing options...
volvolove Posted August 3, 2004 Author Report Share Posted August 3, 2004 So, as a 15G user the 300/70 would be a good thing or not good thing? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted August 3, 2004 Report Share Posted August 3, 2004 So, as a 15G user the 300/70 would be a good thing or not good thing?←good for holding more boost during the gear, however worthless to hold more boost at the end of the gear (redline) Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 3, 2004 Report Share Posted August 3, 2004 how hard is it to bolt up Link to comment Share on other sites More sharing options...
swdracr Posted August 3, 2004 Report Share Posted August 3, 2004 how hard is it to bolt upIt's a little bit of a pain to get to one of the bolts (there are only two), but as far as fitment, it bolts right up. Link to comment Share on other sites More sharing options...
donstruke Posted August 4, 2004 Report Share Posted August 4, 2004 It didn't help me hold boost at higher RPMs at all; the limit there is the turbo, not the wastegate. What it did do was allow me to run higher boost without using a MBC. It just has a stiffer spring than the 150/40.←So (here comes another confirmation of my Dumb-o-quotient) why not just put the 300 spring on the 150 or is it not do-able? Link to comment Share on other sites More sharing options...
Bay13 Posted August 4, 2004 Report Share Posted August 4, 2004 why not just put the 300 spring on the 150 or is it not do-able?Looking at the Volvo parts list, the internals of the waste gate are not availabe. I don't think you can get to the spring without destroying the waste gate. Link to comment Share on other sites More sharing options...
NateB Posted August 4, 2004 Report Share Posted August 4, 2004 What's the part number for this 300/70 Wastegate and how much does it cost? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted August 4, 2004 Report Share Posted August 4, 2004 8918952 - 300/70 wastegate - thanks to Patrick (swdracr) and Jesse at the top of the page under "check part #'s" Link to comment Share on other sites More sharing options...
Guest Guest_NateB_* Posted August 5, 2004 Report Share Posted August 5, 2004 8918952 - 300/70 wastegate - thanks to Patrick (swdracr) and Jesse at the top of the page under "check part #'s"←Thanks for the part number !Do you know how much they go for ? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted August 5, 2004 Report Share Posted August 5, 2004 Thanks for the part number !Do you know how much they go for ?←I could call my local dealership to get a quote Link to comment Share on other sites More sharing options...
Guest vspeed Posted August 6, 2004 Report Share Posted August 6, 2004 Volvo is telling me that part number is no good. Any help would be appreciated.Regards. Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted August 6, 2004 Report Share Posted August 6, 2004 Volvo is telling me that part number is no good. Any help would be appreciated.Regards.←ask for the wastegate off the 19T turbo Link to comment Share on other sites More sharing options...
