USMC850T Posted March 20, 2007 Report Share Posted March 20, 2007 www.jeff.colegrove.usfor my photography stuff. I put up the carslile vette show, detriot auto show, a few airshows and some random stuff. this summer I'm going to bring my camera to an F1 race and a superbike race I know about the tips page and that the banner shifts slightly from page to pageThis is one of my favorite from 2 years ago. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted March 20, 2007 Report Share Posted March 20, 2007 I for 404'ed :( Link to comment Share on other sites More sharing options...
T5BRICK Posted March 20, 2007 Report Share Posted March 20, 2007 kill the wwwjeff.colegrove.us Link to comment Share on other sites More sharing options...
Che'_Moderator Posted March 20, 2007 Report Share Posted March 20, 2007 Safety Wire!Looks like the 30mm uses a left thread pitch on the jesus nut Link to comment Share on other sites More sharing options...
Denovae Posted March 20, 2007 Report Share Posted March 20, 2007 Safety Wire!Looks like the 30mm uses a left thread pitch on the jesus nutonly you would sit there and notice the safety wire is going the wrong way for a right hand threaded bolt. Link to comment Share on other sites More sharing options...
Mesoam Posted March 20, 2007 Report Share Posted March 20, 2007 you're missing a contact pagei've allways liked the simple viewer makes for clean /easy nav Link to comment Share on other sites More sharing options...
ArmyINFDoc Posted March 20, 2007 Report Share Posted March 20, 2007 I love A-10s but they stole them from our base <_< Link to comment Share on other sites More sharing options...
Che'_Moderator Posted March 20, 2007 Report Share Posted March 20, 2007 only you would sit there and notice the safety wire is going the wrong way for a right hand threaded bolt.No its a left handed thread Link to comment Share on other sites More sharing options...
SkyWriter Posted March 20, 2007 Report Share Posted March 20, 2007 i always loved this image. just exactly what is that fog and exactly what causes it? why is this one cone shaped while another one isn't? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted March 20, 2007 Report Share Posted March 20, 2007 i always loved this image. just exactly what is that fog and exactly what causes it? why is this one cone shaped while another one isn't?Their called vapor cones. They are caused by the cooling of the air around the jet condensing moisture out of the air. Same theory as a air vortex cooler. What your seeing in that picture is the airframe exceeding the sound barrier at that elevation. And the multiple vapor zones usually around the nose, tips, and canopy converging to a single cone. Link to comment Share on other sites More sharing options...
USMC850T Posted March 20, 2007 Author Report Share Posted March 20, 2007 It's an area of low pressure that builds in intensity as the aircraft approaches the speed of sound. Under the right conditions, that area of extreme low pressure will have enough of a temperature drop to meet the dew point and voila, it gets filled with water vapor. You will typically only see these in transonic speeds, .95 mach to 1.05. I've been to tons of airshows and that is the first time I saw one as large as that. You will see wingtip vorteces far far more often, where under high G manuevers, condensation trails form at the very tip of the wing, or sometimes along the root or LEX. Link to comment Share on other sites More sharing options...
USMC850T Posted March 20, 2007 Author Report Share Posted March 20, 2007 O the shape, it comes from the shape that the pressure waves take at different speeds. At lower speeds, it is more flat and located slightly in front of the nose of the aircraft -As the aircraft accellerates to the speed of sound and through it, those waves angle back from the nose, then the aircraft passes through them - like this A skilled pilot can dance the cone back and forth on his jet B) Link to comment Share on other sites More sharing options...
Che'_Moderator Posted March 20, 2007 Report Share Posted March 20, 2007 O the shape, it comes from the shape that the pressure waves take at different speeds. At lower speeds, it is more flat and located slightly in front of the nose of the aircraft -As the aircraft accellerates to the speed of sound and through it, those waves angle back from the nose, then the aircraft passes through them - like this A skilled pilot can dance the cone back and forth on his jet The 16s here with the 33rd do that in front of one of my houses all day as its over the water and their flight path to the ranges here. Usually ~ 200 ft off the deck you will hear thumpTHUMP as the first ones goes by and over the next 5 minutes 3 more usually follow. The 16s usually have two cones on them when they go mach. Canopy and off the tail. Been here 8 years and its still fun to watch. Lately all we have in this air space though is drones and the Stealths are hear from some reason. Link to comment Share on other sites More sharing options...
Mesoam Posted March 20, 2007 Report Share Posted March 20, 2007 http://video.google.com/videoplay?docid=-3...e+sound+barrier Link to comment Share on other sites More sharing options...
gdizzle Posted March 20, 2007 Report Share Posted March 20, 2007 only you would sit there and notice the safety wire is going the wrong way for a right hand threaded bolt.Usually items that spin clockwise have threads going counterclockwise... and vise versa ;) Link to comment Share on other sites More sharing options...
