Nytefog Posted April 2, 2007 Report Share Posted April 2, 2007 Hi, rJust recently i've notice while comming to a stop, or sitting at a stop light, my v70s rpms will drop to 500 rpm, run rought and make like its about to stall but only for a second then return to regular without a problem. Any specific reason this might be occuring? The vehicle has 67000. From doing a search i plan on cleaning the throttle body and probably replacing the fuel filter.Thanks-Patrick Link to comment Share on other sites More sharing options...
Plan_B Posted April 2, 2007 Report Share Posted April 2, 2007 My wagon did the exact same thing, once I replaced the spark plug wires the problem went away :) Link to comment Share on other sites More sharing options...
Oreo931 Posted April 2, 2007 Report Share Posted April 2, 2007 This in in the wrong section but oh well. Maybe you should try cleaning out your MAF sensor. Link to comment Share on other sites More sharing options...
Plan_B Posted April 2, 2007 Report Share Posted April 2, 2007 This in in the wrong section but oh well. Maybe you should try cleaning out your MAF sensor.Who is it in the wrong section? Link to comment Share on other sites More sharing options...
Oreo931 Posted April 2, 2007 Report Share Posted April 2, 2007 QUOTE(Plan_B @ Apr 2 2007, 11:12 AM) ←Who is it in the wrong section?He has a 1998 V70 T5 and this in in the 1999 and later section. I guess it doesnt really matter. Link to comment Share on other sites More sharing options...
Plan_B Posted April 2, 2007 Report Share Posted April 2, 2007 He has a 1998 V70 T5 and this in in the 1999 and later section. I guess it doesnt really matter.He most of edited his post, and if so, so what....stop being a dick to people Tony :angry: Link to comment Share on other sites More sharing options...
Oreo931 Posted April 2, 2007 Report Share Posted April 2, 2007 QUOTE(Plan_B @ Apr 2 2007, 12:55 PM) ←He most of edited his post, and if so, so what....stop being a dick to people Tony Grant stop being an idiot, its not a big deal...I even offered a suggestion to help fix his problem.Back on topic ;) Link to comment Share on other sites More sharing options...
Guest white wagon Posted April 3, 2007 Report Share Posted April 3, 2007 I just went through something similar to this with my 98 V70, although my problem was more rough and rolling idle after a hot restart. The car had begun to throw random misfire codes. 103K on the clock. I had already done plugs, cap and rotor at 90K.I changed the plug wires (they were original), cleaned the MAF sensor and filled up with some 93 octane. It now idles like a Swiss watch and accelerates like a scalded dog! Some guy cut me off this morning and I almost wound up in his trunk when I pressed the gas. Gotta be more careful when that turbo kicks in now! Good luck with yours! Link to comment Share on other sites More sharing options...
icelandic Posted April 3, 2007 Report Share Posted April 3, 2007 Way to go. That is exactly where you have to start. Sure signs of a dirty TB.Good LuckHi, rJust recently i've notice while comming to a stop, or sitting at a stop light, my v70s rpms will drop to 500 rpm, run rought and make like its about to stall but only for a second then return to regular without a problem. Any specific reason this might be occuring? The vehicle has 67000. From doing a search i plan on cleaning the throttle body and probably replacing the fuel filter.Thanks-Patrick Link to comment Share on other sites More sharing options...
Nytefog Posted April 3, 2007 Author Report Share Posted April 3, 2007 Thanks guys your Information is much appreciated. Link to comment Share on other sites More sharing options...
