16t Arrived Today
well, we got eveything worked out after about 12 hours of work. although there still seems to be some minor problems that i'm not too sure what the causes are.
when i first started it up, there was white smoke coming from what looked like the turbine and also out of the exhaust. i am praying that this is just the oil burning off. the only reason i would think otherwise is that upon closer examination it looked like it may have been seeping out of the block just above where the turbine is.
there is a definite leak of something because where i park there is a big pool of stuff. but it's hard to tell because the ground is already wet and it all landed in a puddle.
  • Replies 40
White smoke is typical if the coolant or oil went everywhere when you pulled the lines off when uninstalling, just burns off basically.
Big pool of what? Is your oil level or coolant level down? My money's on coolant, because a pool of oil you wouldn't be posting.
my dipstick for my oil is broke so i had to order a new one from the stealership. it's on the way. i keep having to fill up the coolant but it seems to be staying now. i will have to take a look at it a little later tonight to see if it's gone down again.
Hear any ticking from the engine when you start it up that then goes away?
The coolant you'll have to fill up a couple of times, as you noticed, when you do a turbo swap if it all drains out. That's normal, what's not cool is the puddle under your car. Anyway you can touch it or taste it? Does it feel thick, oily, or taste sweet like coolant?
there is no ticking. however when i took it out today and went WOT i blew the intercooler pipe right off. i guess i didn't tighten it down good enough the first time. but it's fine now. the white smoke the second time i went WOT after i got the pipe back on was coming out reeaally bad out of the exhaust. either that or it was just blowing back from the motor. it was hard to tell, but it was like white smoke that covered a three lane the highway. i wish i could describe the smell. almost like rubber burning, but less pleasant.
i went out and stuck my finger in the puddle of stuff, it's rainbow-y so that led me to assume it is oil. it pretty much just felt like water. i didn't really feel like tasting it.
