Oreo931 Posted April 7, 2007 Report Share Posted April 7, 2007 oreo.. i have a narrowband. i know flame me.. . like i said i just noticed after using the seafoam the gauge started reading in the lean area for awhile but now since ive driven the car its reading like it used to. I think it was picking up the seafoam in the system...how is yours hooked up? did you splice into the O2 sensor or did you have a seperate bung welded in and everything? Link to comment Share on other sites More sharing options...
Phil94850 Posted April 7, 2007 Author Report Share Posted April 7, 2007 i spliced into my O2 Link to comment Share on other sites More sharing options...
Plan_B Posted April 8, 2007 Report Share Posted April 8, 2007 I just got back from Napa and they said to replace the fuel filter if you are going to do seafoam, so I got something less invasive :) Link to comment Share on other sites More sharing options...
Jaxx Posted April 8, 2007 Report Share Posted April 8, 2007 do you have a downpipe and exhaust? cause if not you wont get all 17psi. most people dont see 17psi with stock exhaust, just too much gas to go through an S like turn and small jerk exhaust. just what i think is happening.keep in mind, seafoam is O2 sensor safe, but the stuff that it takes out isn't. carbon build up can really messup your O2 sensors when it comes out so quickly when you do seafoam. Link to comment Share on other sites More sharing options...
Phil94850 Posted April 8, 2007 Author Report Share Posted April 8, 2007 my O2 needs replacing anyways, the rear one keeps throwing a code Link to comment Share on other sites More sharing options...
greasefingers Posted April 8, 2007 Report Share Posted April 8, 2007 This might be an added PITA suggestion but maybe removing the O2 sensor first before running the seafoam thru the throttle body would be appropriate. That way a lot of the carbon will exit the O2 sensor port. Then replace the O2 sensor and pour the remaining amount of solvent into the gas tank.If you are going to use a new O2 sensor then this is absolutely how I would do it. Link to comment Share on other sites More sharing options...
Phil94850 Posted April 8, 2007 Author Report Share Posted April 8, 2007 grease .. yep i agree. Its cold as heck up here right now, im waiting for the weather to warm up some and im gonna do my O2. If it was nicer up here i would have dont it that way all in one shot Link to comment Share on other sites More sharing options...
