bogelo Posted August 6, 2004 Report Share Posted August 6, 2004 Does this amp use a special connector for wiring the speaker and the power? TIA Link to comment Share on other sites More sharing options...
Veneficus Posted August 6, 2004 Report Share Posted August 6, 2004 It shouldn't need to be done any differently than any other amp. Just run your remote then your positive line and then ground it and it should work. As far as wiring your speakers they generally all have different settings and it usually doesn't matter if they area d class amp or a a/b class. Link to comment Share on other sites More sharing options...
Bing_0 Posted August 6, 2004 Report Share Posted August 6, 2004 whcih model ads is it? some do, some dont, did you get it used and you see holes where the wire connectoers should be?b Link to comment Share on other sites More sharing options...
Bing_0 Posted August 6, 2004 Report Share Posted August 6, 2004 i am off to work in case what I posted above is your case, you can buy those plugs.click here for those ads replacement plugsb Link to comment Share on other sites More sharing options...
Veneficus Posted August 6, 2004 Report Share Posted August 6, 2004 oooooh, haha, I thought he meant something else... Link to comment Share on other sites More sharing options...
